Computers & Internet Logo
g karthick Posted on Jun 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to configure the dlink dsl 1504g lan extender
guruaid_cs
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 906 Answers
  • Posted on Jun 04, 2016
guruaid_cs
Master
Level 3:
Renaissance:
Answers
906
Questions
0
Helped
153322
Points
2073
To help you configure Dlink DSL 150G Lan extender, please follow the instructions given on the link below:
https://dlink-manuals.org/dlink-dsl-1504g-user-manual/20/
GuruAid.com
1504g lan extender user name and passworld
D_Link, you left off the NAME of it, (not good that !)
we have no idea at all what your PW credentials are.
how could we?
first off , you have router with wifi already, right
question1: how owns this device, you or the ISP?
question2, if ISP owned they told you your credentials.
if you own it and bought it then you know your credentials if you forgot them then start over.
setting up the extender is covered in the manual for it.
did loose that too?
It must be joined tot he other wifi.
some extender also can be wired to the main router. with an ethernet cable, that works best of all. (for better coverage)
http://dlink.co.in/pdfs/products/DSL-1504G/DSL-1504G_ds.pdf
How Config D-Link DSL-1504g Lan Extender
If using lan just connect the extender to the router with a lan cable. The extender will no need to setup.
How to make lan extender (D' Link DSL-1504G) to CU & RT
www,mywifiext.net for extenders www.routerlogin.com for routers.
the IP address is usually found on the case of the router along with the default user/ password login. You can google for default ip pass logins for any router.once you are in you can set things up.however you router should have come with a disc which would make the whole process easier.
How to reset factory default in Dlink G.SHDL 1504G Lan Extender?
You will need to connect Via the ethernet port on your Dlink and Computer direct first then you can configure your router from there and reestablish the web link afterwards.
Pl help me to open web page for configure dsl-1504g
http://dlink-manuals.org/dlink-dsl-1504g-user-manual/
plug router and a computer together via ethernet cable and type in 192.168.0.1 and havre computer setup to use dhcp in internet settings. Try user name admin password admin
if it does not accept the default password and user name you will have to read up in the manual how to reset dsl 1504 to factory settings.
1helpful
How to configuring D LInk DSL 1504G LAN Extender
i have a small dought in dlink dsl 1504g lan extender
did i want to configure the lan extender
Grand Canyon Tech
Grand Canyon Tech
