as beko is Turkish made You need first to cancel the spin program (or any program u wrongly started)
to do that Power on washing machine Wait until the spin program starts
Then press and hold your finger on start button for 4 seconds You notice the middle led with "tub symbol " and right led " vertical line with a pointing arrow to it" are lit together (or if it have display u see the spin symbol flashing or the play flash flashing depending on your washing machine model) wait for few seconds u notice it stops the pump and program cancelled. Power off washing machine for 10 seconds then power on your unit is ready for desired program to select. Note that u need to do the above steps to cancel the program u want to change. Regards
Go to stop or a program that ir a reset mode. Cheak the make and model and look in you manual that came with the machine. Normally there is a stop mode.
It's actually pretty easy. Try this: press and hold the start button in for 5 seconds.drain pump will start
up.let it complete its routine (takes 2 mins or so).now the machine has
reset.select program as normal and retry Hope this helps
