Washing Machines Logo
Bianca Curran Posted on May 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to find out which color plug for back into the circuit board I didn't take note. Green blue black & magenta for the U3 J1 and J2 slots
  • Official Brand Answer 2,267 Answers
  • Posted on May 10, 2016
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290095
Points
2557
Hey Bianca, thank you for your post!
I see that you need help with wires on the back of your Electrolux washer. In order to check on any wiring diagrams I would need to have your model number. You can locate the model number on the door frame of the washer. With that information I would be able to assist you further. -Matt
1 Related Answer
Anonymous
  • 958 Answers
  • Posted on Jul 11, 2008
SOURCE: WD62 programmer wiring
hi robbie,
you can slowly try each plug to every slot in the board. they are not interchangeable. they have keys that would not fit to other slots.
i hope i was able to solve your problem..please rate me...tnx
drcool299
2helpful
Need help with my sch-s738c Samsung phone . android come on telling me to reboot
Kenny, May have to rest, links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung Galaxy Centura hard factory reset
Global Download Center
HOW DO HARD RESET MY SAMSUNG SCH S738C Im locked out of my samsung sch...
I have a 2002 jeep grand cherokee limated,the blower motor resistor wireing shorted out at the plug connection the control circuit to the resistor,I need to know the color code for the j1,j2,j3 termals on...
I've seen a few of these and the easiest fix is to replace both the blower motor speed controller/resistor and the wiring harness connector. I've tried fixing the connector but the repairs don't last because of the heat generated at the connector if everything isn't just right. You can purchase the connector, which comes with color coded pigtail wires attached, from the dealer and it's a fairly easy and permanent fix. Hope this helps and good luck!
2helpful
11helpful
3answers
Whats samsung gt c3222 mobile security code no.
when configer a gmail on my samsung c3222 handestet they gave error DNS unavilable i am useing idea network
My samsung ipod model yp-u3 need software to download songs, where i can find
Please check this link below for help:
www.ptf.com/???samsung/???samsung+ipod+yp+s3+software
www.dl4all.com/search/???samsung+ipod+software.html
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
3helpful
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
