20 Most Recent
Samsung SyncMaster 720N Monitor Questions & Answers
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
12/7/2022 10:01:04 AM •
Samsung...
Answered
on Dec 07, 2022
The brightness menu screen is stuck on!
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
7/18/2014 3:13:45 PM •
Samsung...
Answered
on Jul 18, 2014
A window saying Brightness is constantly popping
this monitor is triky.
try pressing brightness key and try playing with other keys EXCEPT PoWER button
this is only thing you may try.
THats it. bettter is to replace monitor
rate this solution and comment to get further assistance.
2/17/2014 8:29:12 PM •
Samsung...
Answered
on Feb 17, 2014
Have samsung syncmaster 720n monitor. adjustment
Trying the hold down power button for count of ten (did count of twenty just to make sure) didn't work. Menu came back up. Will try unplugging control chip next (this fix doesn't make sense to me ) will see if monitor will work without chip>
9/15/2013 10:29:03 PM •
Samsung...
Answered
on Sep 15, 2013
Syncmaster 720n
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
4/14/2012 9:33:45 AM •
Samsung...
Answered
on Apr 14, 2012
Samsung SyncMaster 720N ...
Peace.
11/20/2011 10:26:45 PM •
Samsung...
Answered
on Nov 20, 2011
Why my montior keep said
just go to the settings of your monitor..got to menu of it and try to find the unlocked.
9/19/2011 1:11:38 AM •
Samsung...
Answered
on Sep 19, 2011
My monitor is turn off
That means your video card and/or your monitor does not support that resolution. Check what the maximum resolution your monitor can handle. You can find that out by asking your monitor's manufacturer or looking up the model of your monitor online. If you're sure that the monitor can handle that resolution but its not working, try updating or reinstalling your video card driver.
7/19/2011 4:09:24 AM •
Samsung...
Answered
on Jul 19, 2011
