Video Cameras Logo
P
Philip Lafuze Posted on Apr 22, 2016
Won't power up when plug into ac outlet.
Was made in 1196, hasn't been used for 10 or more years
4 Related Answers
Anonymous
  • 337 Answers
  • Posted on Sep 25, 2006
SOURCE: Doesn't power ON
If you have no indication of power at all,(no lights,no display)the fuse is the first component to check but the vcr has be unplug from the wall when you remove the top cover and remove the fuse to check it.Be carefu.
Anonymous
  • 8 Answers
  • Posted on Nov 05, 2011
SOURCE: Kindle_won't_chrge
Possibly a new battery, or charger. But it also could be that inside your device could have detached/unsoldered from the connection slot. If you know how to use soldering with electronics then that may be able to get it working if that is the case. I would not recommend this approach, the manufacturer or dealer may have to get it taken cafe of for you.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jul 17, 2012
SOURCE: No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Anonymous
  • 444 Answers
  • Posted on Nov 03, 2012
SOURCE: my supersonic dvd won't spin.I have the ac adaptor plug into the power outlet
Take it back where you got it from, End get your money back ,
1helpful
Craig tv plugged in stand by light won't come on and tv won't play
It could be. But make sure the power outlet is ok. Please try on a different power outlet.
Wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Situation Not Resolved:
If the system still won't power on, the system and AC adapter will need to be repaired. To start the repair process, click here.
Wii Console Turns On, But Has No Power Light Situation:
  • The power LED on the system does not come on, but the system still powers on and plays
Information:
If the Wii Console is still working normally, it is likely that the power LED is broken.
This issue will remain limited to the Power LED, and will not get any worse.
Unless the system is having other problems, continue using the console regularly for a few weeks to determine whether this interferes with the enjoyment of game play.
If, after using the system for awhile, the Power LED not coming on is too distracting, the Wii Console does carry a one-year warranty.
We are happy to inspect and, if necessary, fix the system at no charge within the warranty period. To start the repair process, click here.
function rvl_ts_sys_power_no_light_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_power_no_light",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_power_no_light_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) } function rvl_ts_sys_power_no_light_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_power_no_light=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_power_no_light_techDif(){ //it broke document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_power_no_light_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_power_no_light_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) }
My wii won't turn on
Information:
What To Do:
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
2helpful
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Kelly
3answers
2helpful
2answers
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
