20 Most Recent JVC GR-DVL305 Mini DV Digital Camcorder Questions & Answers
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... | Answered on Nov 13, 2017
not sure on this one but it might be the heads in your vid cam may need cleaning.
or the tapes are not running straight on the heads or the rollers in side.
if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp.
try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture.
this could also be a head misalignment fault if it is you will have to take it to some one to have a look at.
if any of the above does not work then you will have to take to some one to look at it.
JVC GR Video... | Answered on Nov 27, 2016
Sounds as if the battery needs replacing - have you tried with a spare battery ?
JVC GR Video... | Answered on Oct 08, 2016
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
JVC GR Video... | Answered on Sep 12, 2016
Do you have the sd card that holds the pictures?
Put in computer.
Computer will give you option how to open and save photos.
You do not have to use makers software disc, any photo reader can store your pictures on computer.
JVC GR Video... | Answered on Nov 28, 2015
then don't push pause try record instead .
JVC GR Video... | Answered on Nov 21, 2015
once deleted there is no recovery SORRY
JVC GR Video... | Answered on Jun 01, 2015
Your PC must have a IEEE1394 port (FIREWIRE PORT). If you do not have, you can try PINNACLE DAZZLE to video capture.
JVC GR Video... | Answered on Feb 11, 2015
iPhone can not play AVCHD format directly. You may need to convert it first. Transfer videos from your digital camera to your computer, then convert AVCHD to mp4 or mov format. Last but not least, transfer videos to your iPhone via iTunes. How to Convert AVCHD to MP4 for Free
JVC GR Video... | Answered on Jan 20, 2015
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
JVC GR Video... | Answered on Jan 12, 2015
Manual for this camcorder can be downloaded here for free http://books.jvc.com/booklist.asp?Model=GR-SXM340
JVC GR Video... | Answered on Nov 26, 2014
JVC GR-DVL305 Mini DV Digital Camcorder Logo
Popular Tags
0 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
connect old camcorder new pc
  • Video Cameras
