20 Most Recent Hotpoint RVM1625 Microwave Oven Questions & Answers
Generally, if a microwave is no longer heating it's cheaper to replace it then to fix it.
Hotpoint RVM1625... | Answered on Mar 16, 2015
better call an electrician soon don't want a fire now do we
Hotpoint RVM1625... | Answered on Feb 19, 2015
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hotpoint RVM1625... | Answered on Oct 04, 2011
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Hotpoint RVM1625... | Answered on Sep 24, 2011
sensor fault
Hotpoint RVM1625... | Answered on Jun 28, 2011
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
Hotpoint RVM1625... | Answered on Apr 27, 2011
heatman101
Hotpoint RVM1625... | Answered on Oct 16, 2010
That might be covered on the owner's manual.
If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
Hotpoint RVM1625... | Answered on Oct 03, 2010
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
If the model number is correct, the part number for a replacement motor is WB26X10038. If the coupler is stripped and needs replaced, the part number is WB06X10138. The average price for a motor is about $35. The coupler is less than $20. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Hotpoint RVM1625... | Answered on Jul 13, 2010
If it has that feature, it would be covered in the owner's manual.
Many GE models do. You can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So if you need more free help, please reply back directly to me with your brand and full model number from the tag in or on the unit.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Hotpoint RVM1625... | Answered on Sep 27, 2009
You say all power went out but it is not a breaker. What power went out? In your kitchen? house? or just the machine? Can it be that you are plugged in a circuit that is protected by a GFI?
There normally is a fuse inside an oven on the floor. Unplug the device, remove the cover. DO NOT TOUCH THE SILVER CAN IN THE BACK - LETHAL.
Check the fuse with an ohm meter or contunity checker of some type.
If you need additional assistance, please let me know.
I hope this was helpful for you
a
Hotpoint RVM1625... | Answered on Sep 23, 2009
it seems the thetmal cutoff(TCO) mounted on the magnetron to protect it from overheating is going off.it opens out when magnetron overheats and cuts the power to the control board and after the magnetron cools down tco resets and power to control board is restored with the sign PF(power failure).the fan that cools the magnetron may have gone bad.i think u will need a tech 2 chk it out.
Hotpoint RVM1625... | Answered on Aug 22, 2009
Press the 'display' button for 5 seconds
Hotpoint RVM1625... | Answered on Oct 14, 2008
It sounds like the main board is malfunctioning and needs to be replaced. Depending on the age of the tv, you may just want to replace it. Please post the make and model to help us better assist you.
Thank you for using Fixya and good luck
Hotpoint RVM1625... | Answered on Apr 22, 2008
Pricey little thing I have checked 3 places all say it is NLA I will post it on a nationwide parts order to see if anybody may still have one one in stock
Hotpoint RVM1625... | Answered on Jan 24, 2008
There is a chip that controls TOTAL operation of the microwave, sounds like it malfunctioned. It actually sound like the entire board has malfunctioned. good luck
https://www.6ya.com/mrmmike
Hotpoint... | Answered on Mar 02, 2019
Hotpoint RVM1625 Microwave Oven Logo
Popular Tags
36 questions posted
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Microwave Ovens
Most Popular Question
turn table doesnt rotate
  • Microwave Ovens
