It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
The owners manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811143/TD-10_eG.pdf Try initializing the TD-10. Check page 137. Check page 132 and 133. If the problem is still there, you likely have a jack problem. There might be a bad solder joint where the jack is mounted to the circuit board. If the warranty is up you can do it yourself if you are confident. Otherwise take the module in to have it serviced. Check here to contact Roland:http://www.roland.com/index.html
