Sharp XE-A102 Cash Register Logo
w
walid assaad Posted on Apr 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sharp in p mode - Sharp XE-A102 Cash Register
Nicola Conroy
Level 3:
  • Master 1,428 Answers
  • Posted on Apr 04, 2016
 Nicola Conroy
Master
Level 3:
Answers
1428
Questions
Helped
715222
Points
3702
If you put in REG mode and hit #/SBTL it will clear the "P", but it may modify some of your programming depending on what you were doing (such as keying in an amount and department). Usually it is preset unit price for a department key that may change. You can check this on the report. If you keep an old programming report, you can check to see if anything has changed. If it has, go back to PGM mode and reprogram.
Sharp 14V-R70M Default Service Mode
First, please check that your one of your tv remote buttons isn't stuck because this could cause your tv to continuously go into a certain mode.
You might then attempt to factory reset your tv to stop the service-mode issue. Please reference your device's manual to help with this. Thank you.
1helpful
2answers
Can't get closed captioning to come on. When I press CC I get the same box on the display as when I press DISPLAY. Neither box allows me to scroll down to CC: -- where I'm guessing I should be able...
First suggestion is to check the cable or dish remote if using one.
boxes have CC built in, if not using a box make sure the sharp remote is in TV mode watch the mode light while pressing the mode button to make sure.
Sharp manuals are on sharps website
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
3helpful
How do you restore the Sharp EL531W calculator to the original settings.
For the manual see link
http://sharp-world.com/contents/calculat...
The downloaded manual pages 3 and 4 states, click the "setup 03" key and it will change to normal mode.
10000/8.1=1234.5678901 (normal mode)
setup 00 setup13 1234.568 (fix mode tab=3)
setup 01 sci mode
setup 02 eng mode
setup 03 normal mode
or just click the reset switch behind the ( Sharp el531w ) calculator, data will be deleted.
Manual for calculator sharp el 573
My Sharp El-573 calculator is in scientific mode and nothing I do will put it back in regular arithmetic mode. Please tell me how to switch it back. Thanks for any help! Barbara
1helpful
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Top Sharp Retail Supplies Experts
k24674
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
