20 Most Recent Sharp XE-A102 Cash Register Questions & Answers
My register only beeps after it's been reset. How can I fix this. Sharp xea102
Sharp XE-A102... | Answered on Feb 21, 2019
Make sure the batteries are not flat. It usually indicates a lack of battery power and it is losing the programming because of it
Sharp XE-A102... | Answered on Jun 08, 2018
You have started reprogramming it but didn't finish. Press SUBTOTAL twice
Sharp XE-A102... | Answered on Dec 04, 2016
MASTER RESET
Master reset: Clears all the memory and initializes each preset parameter. The master reset should be performed by using the following procedure.
1. Turn off the power (Power OFF). (See Note 1.)
2. Remove the memory back up battery from ECR.
3. Turn the mode switch to any position other than Power OFF.
4. Turn on the power (Power ON). (See Note 2.) When the master rest is completed, the buzzer sounds three times.
5. Install the memory back up batteries back into the ECR. The master reset can also be accomplished in the following case. (See Note 3.)
Note 1) Power OFF: Means disconnecting the AC power supply to the machine. (Specifically, unplugging the machine.)
Note 2) Power ON: Means connecting the AC power to the machine. (Specifically, plugging in the machine.)
Note 3) In case a power failure occurs when the machine has no battery installed, the master reset operation is automatically performed after the power has been restored.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sharp XE-A102... | Answered on Jun 05, 2016
If you put in REG mode and hit #/SBTL it will clear the "P", but it may modify some of your programming depending on what you were doing (such as keying in an amount and department). Usually it is preset unit price for a department key that may change. You can check this on the report. If you keep an old programming report, you can check to see if anything has changed. If it has, go back to PGM mode and reprogram.
Sharp XE-A102... | Answered on Apr 04, 2016
Replace the batteries
Sharp XE-A102... | Answered on Feb 08, 2016
Press the CASH TEND button
Next to the paper roll there are small 3 batteries, remove them and wait for 2 mins and then insert them back
Sharp XE-A102... | Answered on May 16, 2014
Use 0 for non-tax and 1 for taxable
If you wanted to stop that printer from running, you can't. Aftre evry trnsactions it prints and is very slow. You can change the preinter and put an er42 printer that is a bit faster
Sharp XE-A102... | Answered on Mar 18, 2014
do an initial reset and restart
Sharp Retail... | Answered on Dec 28, 2018
Check you keyboard if there isn't any key that is stuck down
Sharp Retail... | Answered on Feb 22, 2016
If its feeding paper but not printing, make sure that you are using the correct thermal paper and that there is no extra bits of paper stuck under the printing head. Otherwise it might need a replacement printing head. If its not feeding the paper at all, then make sure that the receipt is turned on.
Sharp XE-A102 Cash Register Logo
15 questions posted
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Retail Supplies
Most Popular Question
gives me 00000000 screen shall clear
  • Retail Supplies
