Install new cartridge than this massage display on the screen.(face down feeder)
SOURCE: Continuous Alignment Message, Please Wait.
Click here and follow the instructions to do a partial reset on your printer and try to align cartridges. Click here for instructions to align cartridges.
SOURCE: hp officejet j3680 all-in-one printer no scan options
Disconnect the USB Cable from printer
Unplug the power cord from printer ( while printer is on )
Holding the power button on printer, connect it back.
Later connect the USB Cable. try to scan. IT should work.
If it doesnt, follow the steps on this link :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&lc=en&dlc=en&product=3441026
SOURCE: HP LaserJet M5025 MFP scans
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
