First be sure the handset battery is well charged as a weak
battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
( I ) Deregister the handset:
Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
( II ) Now, to re-register the handset:
Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
...or it will display "Registration Failed"
If "...Failed", try from ( I ) again.
