I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier) https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here. The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa.
Type "YourModelNo" into the "Model #:" window, then clicked search.
Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
Click "View Illustrated Parts Breakdown"
It may help answer yuor question. RemingtonPower has production and replacement parts are very to find.
I've 7 chainsaws. 6 of them empty the oil tank overnight if I don't empty it. HTH
Lou
Take it back to where you purchased it or contact them by email/phone and explain your problem (have saw in hand). Together you can solve this. We cannot find the model number on your saw from here. GL
Lou
According to the manufacturer, "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." I will need the actual model number of your saw (it should be loacted on the saw it's self) to see if I can find the manual for you. I hope this helps so far...
