Main system control memory IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Hi ricky
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
The TV is in Picture-in-picture mode. The small picture is the last active source. The bigger area is the current source connection, but there's no signal.
Read the manual about how to operate the Picture in Picture feature.
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a new long LCD inverter board for the replacement.
if you have cable tv try unplugging and plugging in that cable if that doesnt work you might have a bad cable. check for damage along the cord or bends in the metal ends sometimes that can also be the problem
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
