MODEL #EI24D50QS
Hey Robert, thank you for your post!
Based off the information you have provided your Electrolux dishwasher is displaying an error code of "CO" and you would like to clear it out. The error code "CO" means that there is a miscommunication within your dishwasher. The best way to clear the code out is to perform a reset and you can do that by disconnecting the power cord for at least ten minutes. If the code continues to display this could mean that your keypad, a wiring harness, or control panel may need to be replaced and I would recommend having a professional technician out. They would have the appropriate tools needed to disassemble your dishwasher and test each component. This will help protect you from any unnecessary part purchases. -Matt
SOURCE: how to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
Good Afternoon Jodi, thank you for your post!
Based off what you have described your Frigidaire dishwasher is displaying an error code "CO" and will not run. An error code of "CO" may be a miscommunication within the control panel and you can clear that error code by disconnecting power from it for roughly ten minutes. If you continue to experience an issue with your dishwasher I would suggest contacting a professional technician for a diagnosis to be completed. I hope this information is helpful. -Matt
