20 Most Recent Electrolux EIDW6305GB 24 in. Built-in Dishwasher Questions & Answers
Error code 6
Good Morning sewblessed - Generally, error code E06 means that when the unit is in the dry cycle, the control does not receive the proper speed feedback from the lower fan. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, then more than likely the lower fan will need replacing and I would recommend connecting with an experienced appliance repair tech to assist further.
6/17/2013 12:23:25 PM • Electrolux... • Answered on Jun 17, 2013
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
10/3/2012 4:06:10 PM • Electrolux... • Answered on Oct 03, 2012
Low rinse code in electrolux dishwashers
Check your water pressure in your home and to the unit. Also make sure the sprayer arms are not loose or broken. Water pressure is the only thing that moves the arms around for any cycle.
8/9/2012 7:17:41 PM • Electrolux... • Answered on Aug 09, 2012
0answers
Error code 11
Be the first to answer 10/11/2011 3:27:38 PM • Electrolux... • Posted on Oct 11, 2011Be the first to answer
My dishwasher is not draining
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
8/25/2011 1:59:54 AM • Electrolux... • Answered on Aug 25, 2011
0answers
What does the
Be the first to answer 6/30/2010 12:14:58 PM • Electrolux... • Posted on Jun 30, 2010Be the first to answer
2answers
Our unit is flashing an ER 01 message. The book
If you have Tried Unplugging the Unit as well as you are sure that there is no Clogging in the Hose or the Pump, it sounds like it is Defective Control;Board.
Now. i have seen People calling Electrolux and usually they would either replace the hose or tell you to check filter or so or offer you a Leak Repair Kit which might not Solve the Problem as you do not have any Leak or Clogging. In the end, they would also accept that it is Faulty Control Board and Needs Replacement.
It is advisable that, if it is under Warranty, get it replaced directly by Company. If not, then you need to take a Wise Decision whether it is a Time to Get it repaired or time for a new one.
I could only advise you, if the Dishwasher is more than 4 years old and the cost of repair is more than half of the new one, then i should recommend you to go for new one unless Repair Makes sense.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
12/26/2009 2:44:15 PM • Electrolux... • Answered on Dec 26, 2009
How do I improve the drying in my electrolux
The energy efficiency that has so much attention by the EPA has made it so that they probably will not dry completely any longer. Has the unit ever dried completely before? If it hasn't, then the only thing you can do is adjust your dishes so the water will not stand in the bottoms of cups, etc.
You might also check your heated dry "feature" on your dishwasher to assure that it has been selected to dry at optimum heat temperature. Also, do not open the dishwasher before the drying cycle has been completed.
Bosch has the best drying dishwasher model made so when it's time to replace this unit, choose a higher end Bosch for the best drying and the quietest models available.
We hope this answers your questions and should you need to contact us, you may do so at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service.
We hope to be able to assist you again. Thanks, Ella
11/11/2009 8:23:26 PM • Electrolux... • Answered on Nov 11, 2009
Water not draining out all the way. Standing inside bottom of washer, about 1" deep. Is this normal?
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
6/2/2009 12:16:50 AM • Electrolux... • Answered on Jun 02, 2009
There is water standing in the bottom makes dishes smell musty when drying
There should be some sort of filter at the bottom of the machine, try popping that off and cleaning it off manually, also make sure after you take off the filter plastic that the hole under it is not clogged. if it is a must CAREFULLY run a coat hanger into the hole to clear any obstructions.
6/1/2009 3:15:43 AM • Electrolux... • Answered on Jun 01, 2009
Anti flood reset on a Electrolux washing machine
See page 28 Solution to Common Problems in user manual for help User manual Electrolux ELFW4222AW (English - 32 pages)
1/20/2024 1:26:42 PM • Electrolux... • Answered on Jan 20, 2024
Electrolux EIDW6305GB 24 in. Built-in Dishwasher Logo
27 questions posted
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Dishwashers
Most Popular Question
water not draining out all way standing
  • Dishwashers
