You will have to strip the door down to be able to repair the hinges, you will not fix them by yanking the door.
Sounds like the hinges were bent, can try to straighten them out, you may need to disassemble door panel. Hope that helped.
You can try the ole faithful knucklehead approach(which I have done in the past, without much success, but I felt better) by
giving the door a bit of an upward yank? try not to yank hard enough to lift the washer off the floor or break it. Either way we know what caused the problem, so it will be with the hinges bent or broken. Hope this helped Tim
