Waiting for EC is engine controller failure you need to change EC or main board
Usually it fails while firmware upgrade time if you switch off or wrong insertion of powersupply connector in V6 and V5
Based on your error you could have a P7000 or a P8000, Either way it is normally the main logic, but there are 2 for each machine.
P7000 V5
PRINTRONIX 250299 001 HURRICANE V5 PPC P7000 New
P7000 V6
PRINTRONIX 253081 991 LOGIC PPC V6 P7000 EXCHANGE New
P8000 LS
P8000 HS
PRINTRONIX 257114 001 CONTROLLER BOARD P8000 New PRINTRONIX 256443 901 CONTROLLER SUBASSY LS 5 10 New
SOURCE: ibm printer loading problem
Hi Twitike24,
Have you tried turning the printer off and on?If so,fully disconnect the printer and restart your PC.Connect again and then switch it on.Problem solved?
If not,try re-installing the printer drivers again.You can download from this
Hp support site in case you don't have the installation disks.
Hope this helps.Thanks!
