20 Most Recent Printronix Line Matrix P5215 Printer Questions & Answers
3answers
Flash a printer
I can email you the Flash Program.
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: Have Ethernet? You can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
11/29/2017 3:30:30 AM • Printronix Line... • Answered on Nov 29, 2017
Printronix P5215. Upgraded this printer to use Eternet card. Whenever i send large print jobs thru my AIX queue the printer will fail at the end of the job and just stop printing. I can switch back to
I've seen a very similar problem with the L5000 series printer. It turned to be that the problem was with HP jetdirect that the customer used instead of the printronix printnet. Several jetdirect were used and all cause a similar problem. When the printronix printnet was used everything worked fine
9/22/2017 7:29:08 AM • Printronix Line... • Answered on Sep 22, 2017
Wording of printing not fit with the paper using.
I'm having some issues figuring out exactly what problem you are describing, but I think you have a page length issue. You can change that under emulation, page format.
10/10/2016 1:49:46 PM • Printronix Line... • Answered on Oct 10, 2016
P5215 firmware download
The firmware for this printer is not available for download via the web as there are hundreds of different types. If you detail the reason you need it (ie error code) I may be able to help.
9/17/2015 3:52:44 PM • Printronix Line... • Answered on Sep 17, 2015
Download the free p5215 driver
Try this site I found just search for the driver that you need for they have that. Just click_here so that you will be redirected to the exact site where you can download a driver for free.
Thanks.
9/9/2011 4:54:34 AM • Printronix Line... • Answered on Sep 09, 2011
0answers
Printronix P5215 not printing full
If it is missing columns of print the shuttle needs cleaning. Ink has migrated to the back of the hammer frets and must be removed and cleaned. If you have not done this , then I would advise getting someone that is trained to do it.
6/16/2011 10:38:02 PM • Printronix Line... • Answered on Jun 16, 2011
Printronix P5215 not printing full columns. I have
If you are missing columns of print (vertically), the ink is making the hammer frets stick. The shuttle probably needs to be removed and the frets cleaned. This is a common problem.
5/2/2011 7:14:18 PM • Printronix Line... • Answered on May 02, 2011
Power up test ram failed
Power off printer.Try removing the ram and clean the socket. Blow it out with air.Reseat ram and try.
10/13/2010 5:32:24 PM • Printronix Line... • Answered on Oct 13, 2010
I need the flash program for Printronix P5215. Can
The flash program is also known as a driver I do believe
Here is that program in the link posted below
http://www.howtodrivers.com/model536551.html
This other link below here is the MANUAL for your printer to keep on hand in your computer if needed. It takes a few minutes to download for it is large in size.
http://www.scribd.com/doc/16855649/Printronix-P5000-Line-Matrix-Printers-Maintenance-Manual
7/18/2010 4:17:36 PM • Printronix Line... • Answered on Jul 18, 2010
2answers
Can you give me url or driver printronix P5215...
Hi..
This link is helpful for you
you need to input the code number on the site before to download.
Hope it may helpful for you
Regards
PCmania
7/15/2009 7:07:28 AM • Printronix Line... • Answered on Jul 15, 2009
Printer does not print in windows XP
Hi..
Maybe you printer is not installed in your computer, you need to install the driver of your printer,
Regards
PCmania
7/15/2009 6:54:20 AM • Printronix Line... • Answered on Jul 15, 2009
Printronix5003H+ table mismatch
I'm sure you have fixed your printer by now... but reflash the printer.
Flash memory is contained in SIMMs (single in-line memory modules) located
on the controller board. Printer emulation and operating system software are
loaded into flash memory at the factory, but you will install software in some
situations:
• The customer buys the PGL or VGL graphics, Expansion-CT, or IPDS
option after the printer is installed
• The customer needs to upgrade printer software
• The customer needs different emulation software
• You have replaced the controller board
• You have added or replaced the flash memory SIMM
Emulation and operating system software are stored as a compressed file on
a 3.5 inch floppy diskette. This file is “executable.” You will expand it and copy
it into printer flash memory.
You can load software through the serial, parallel, or Ethernet port of the
printer.
1. If the printer has an Ethernet interface, refer to the PrintNet User’s Manual
for the download instructions. You are finished with this procedure. If you
are going to load memory through the serial or parallel port, continue with
this procedure.
2. Make a printout of all saved configurations. (Refer to the User’s Manual.)
(Installing new software erases all saved configurations. You will use the
printouts to restore printer configuration.)
3. Set the printer power switch to O (off).
4. If the printer is already connected to the serial or parallel port of a
computer capable of running an MS-DOS® based PKZIP® self-extracting
file, go to step 11. If not, go to step 5.
5. Unplug the AC power cord from the printer.
6. Disconnect all data input cables from the printer interfaces.
7. Connect a parallel data cable to the LPT1 port or a serial data cable to the
COM1 port of an IBM-compatible computer that is using the PC-DOS™ or
MS-DOS operating system.
NOTE: You can connect the cable to the LPT2 port if the LPT1 port is alreadyin use. The load commands are different if you use this port, as
described in the note after step 18.
8. Connect the data cable to the appropriate I/O port of the printer.
9. Plug the AC power cord into the printer.
10. Power on the computer.
11. Insert the emulation or upgrade diskette into diskette drive A (or B) of the
computer.
12. Make the diskette drive the active drive by typing the following at the DOS
prompt:
A:<return> (If the diskette is in drive B, type B:<return>)
13. Get the name of the compressed file on the diskette by listing the
contents of the diskette; at the DOS prompt type:
DIR<return>
The compressed file on the diskette takes the form FILENAME.EXE
Now write down the complete name of the file with the .EXE extension.
14. On the printer control panel, press and hold down the ON LINE + PAPER
ADVANCE keys. Without releasing the keys, power the printer on.
Continue holding the ON LINE and PAPER ADVANCE keys down for five
seconds, then release them.
NOTE: The port default is CENTRONICS; this is the standard load through
the parallel port. If you want to use the default, continue at step 18.
15. When you see “WAITING FOR PROGRAM DOWNLOAD” on the LCD,
press the < (NEXT) key. “SELECT DOWNLOAD PORT =
DATAPRODUCT” appears on the LCD.
16. Press < (NEXT) again to cycle through the download ports available in
the printer:
DATAPRODUCT (parallel)
CENTRONICS* (parallel) (default port)
RS232-9600 (RS-232 serial, 9600 baud)
RS232-19.2K (RS-232 serial, 19200 baud)
RS232-38.4K (RS-232 serial, 38400 baud)
RS232-115K (RS-232 serial, 115000 baud)
RS422-9600 (RS-422 serial, 9600 baud)
RS422-19.2 (RS-422 serial, 19200 baud)
RS422-38.4K (RS-422 serial, 38400 baud)
RS422-115K (RS-422 serial, 115000 baud)
17. When the printer download port you want to use is displayed on the LCD,
press ENTER. “WAITING DOWNLOAD / PORT = <your selection>
appears on the display.
18. At the DOS prompt on the computer type:
FILENAME.EXE -pb<return>
where FILENAME.EXE is the compressed file you noted in step 13. This
command decompresses the file on the diskette and copies it as a binary
file into the flash memory on the printer controller board.
NOTE: If you are loading the file using the LPT2 port on the computer, enter
the following DOS command:
FILENAME.EXE -pb 2 <Return>
The 9600 baud rate is the only selection older versions of DOS can
use. The baud rate information entered in the following DOS
commands must match the selection you made in step 16.
the load process and status. (LCD messages are listed in Table 2,
page 37.)
CAUTION Do not interrupt the downloading process once it has started.
Interrupting a download will damage the flash memory on the controller
board and PrintNet card ( if installed).
19. When the new program has successfully loaded into memory and the
printer has reset itself, set the printer power switch to O (off).
20. Unplug the AC power cord from the printer.
21. Remove the diskette from the computer and store it with the printer.
LineMatrix
www.sinca.biz
Toby
12/1/2008 3:08:53 PM • Printronix Line... • Answered on Dec 01, 2008
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
12/1/2008 3:01:48 PM • Printronix Line... • Answered on Dec 01, 2008
Printronix Line Matrix P5215 Printer Logo
30 questions posted
Top Printronix Office Equipment & Supplies Experts
k24674
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Matrix Printronix
  • Matrix Printronix
Most Popular Question
download free p5215 driver
  • Office Equipment & Supplies
