GE JKP45 Electric Double Oven Logo
J
Judy Posted on Dec 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does FO code mean? Is this dangerous? - GE JKP45 Electric Double Oven
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Dec 03, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
223278
Points
13385
1helpful
Fo means display
No details given as to to make and model, so we GUESS!!
The F0 error code indicates a Failed Thermistor Control. Resolution: The following is the procedure to clear the circuits for the F0 error code: Power off the unit, wait 5 minutes then restore the power. ... Down" and "Minute Down" keys simultaneously for 3 seconds, then the time of day will be displayed.Jan 25, 2010
What does the F0 error code mean on my Kenmore double ...
Nov 03, 2020 • Ovens
2answers
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 • GE Ovens
What does FO code indicate?.
I showed you what it means before. Did you follow the links?
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced http://products.geappliances.com/appliance/gea-support-search-content?contentId=16238
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). http://www.appliancepartspros.com/repair-help/dacor-fault-codes.html
Dec 03, 2015 • GE Ovens
I have a Jenn-Air double oven drop-in prior to 1997 with a FO trouble light showing. What is the usual repair for the failure?
The FO error codes means that a button on the touchpad has shorted out and teh touchpad needs to be replaced. In some cases you will get that error code because the ribbon cable on the touchpad hasa loose connection at the clock. check that the connection is tight.
The error code can be cleared by pushing the clear/off button,if it returns the touchpad will need to be replaced.
GENE
2helpful
Error code FO
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Code FO is showing in the display
Hi
Thanks for using FixYa. Error code F0 means failed thermistor/transistor in control and to resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
KENMORE OVEN HAS FO ON KEYPAD.ANYTHING I CAN DO BEFORE REPLACING KEYPA..MAYBE RELAY SWITCH
Hello,F0,displaying on your keypad means "stuck keypad" and these mean the relay is turned on and to determine if the problem is with the Key Panel or Control,follow these steps
1. Pushing Clear/Off pad
2. Disconnecting Ribbon Cable from control and wait at least 30 minutes to see if the code reoccurs.
If the code reoccurs, the problem is in the control, that means you have to replace the control.
If the code does not reoccur, the problem is with the Key Panel
Thanks
1helpful
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Fo code what does that mean how do we fix it
f0 error code means faulty E.C.R. (electronic range control) or that it was the keypad replace the ECR
Fo function error code
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at:
[email protected]
Charlie Popeck, P.E.
Consulting Engineer
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
