GE Ovens • Uploaded on Sep 25, 2013
Hi
Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the issue is still
there then the display board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Hi
To unlock the keypad in your GE Oven press and hold the "0"
and "9" buttons for 15 seconds. Hope this helps...please post back for further
assistance.
Daniel
79 questions posted
293 Questions
216 Questions
128 Questions
114 Questions
86 Questions
