SOURCE: washing machine
Hey 4E error comes in case
1. No proper water supply
2. The Outlet pipe sould be at AT LEAST 60 CM to max 90 CM HEIGHT ie to the height of the washing machine, try putting the outlet pipe to the holder at the back of the machine.
[email protected]
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
SOURCE: 4E showing on Samsung Washing Machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: 4E error....samsung J845
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
