Dodge 2011 Grand Caravan Crew Logo
Posted on Oct 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thumping noise coming from right front wheel well?
Recently I have been hearing a thumping noise coming from the passenger side front wheel area that only happens when going over bumps. No torn or damaged boots or rubber bumper things. No oil on shaft of strut. Cannot see up inside the strut mount. It is loud and annoying
fred_therese
Level 2:
Sergeant:
  • Expert 332 Answers
  • Posted on Oct 18, 2015
fred_therese
Expert
Level 2:
Sergeant:
Answers
332
Questions
Helped
74038
Points
852
IT is probably the strut bushing that is worn, The one that you can't see
  • 1 more comment
  • handygirl911
    handygirl911 Oct 18, 2015
    Do you mean the strut mount?
  • fred_therese Oct 22, 2015
    Yes up top where the rod joins the inside of the fender
  • handygirl911
    handygirl911 Feb 23, 2017
    Actually, it was a sway bar link
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
2answers
Have a thumping noise, thought it was cv joint. Removed axels, they are good. Noise is there only when car is moving. Frequency inceases with speed. Wheel bearing roll smoothly.
Rhythmic thumping noise when car's moving - Car Talk
community.cartalk.com/.../rhythmic-thumping-noise-when-cars-moving
Jun 4, 2013 - Hello, I have started hearing faint thumping noise in my Murano, coming from the front most likely.
1helpful
Thumping, grinding noise comes from right front side
most likely a front hub [wheel bearing ]going bad but jack up front side that is causing problem and try to move tire in and out with hands at top and bottom of tire and listen and feel for noise or excess movement it to much movement remove tire an check the upper and lower ball joints as well as the shock/strut but check brakes grinding can also mean pads are metal to rotor but usually grinding and thumping is related to a bad hub
2answers
My 1997 Chevrolet 4wd Blazer pulls to the right and there is this loud thumping noise coming from under the car
Bad arm bushing or bad balljoint. It could also be cause by a loose or bad wheel bearing
1helpful
Thumping noise coming from front tire to passenger seat side
first off how many miles are on the car?does it only do it on bumps in the road?
3answers
Steering wheel vibrates thumping noise
At what speed do you feel the shake and does it only happen when you apply the brakes?
2answers
Thumping at front passenger wheel area
if the noise isassociated with "wheel speed" then it is in the rolling parts... axle hub bearing brake rotor caliper wheel or tires...if it goes away on right turns then you are unloading or separating the issue then...so a hub /wheel bearing /axle issue is most likely...does your brake pedal pulse when you feel it..(riding the brake while driving)..does the steering wheel shimmy ?
Top Dodge Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
