Precor EFX 546i Elliptical Version 4 Logo
R
Robert Reynolds Posted on Sep 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace overlay and key pads - Precor EFX 546i Elliptical Version 4
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Sep 28, 2015
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514911
Points
111994
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH You can find the overlay and keypad on our Website, using your model and serial number.
How to reset a samsung pl201?
.adslot-overlay {position: absolute; font-family: arial, sans-serif; background-color: rgba(0,0,0,0.65); border: 2px solid rgba(0,0,0,0.65); color: white !important; margin: 0; z-index: 2147483647; text-decoration: none; box-sizing: border-box; text-align: left;}.adslot-overlay-iframed {top: 0; left: 0; right: 0; bottom: 0;}.slotname {position: absolute; top: 0; left: 0; right: 0; font-size: 13px; font-weight: bold; padding: 3px 0 3px 6px; vertical-align: middle; background-color: rgba(0,0,0,0.45); text-overflow: ellipsis; white-space: nowrap; overflow: hidden;}.slotname span {text-align: left; text-decoration: none; text-transform: capitalize;}.revenue {position: absolute; bottom: 0; left: 0; right: 0; font-size: 11px; padding: 3px 0 3px 6px; vertial-align: middle; text-align: left; background-color: rgba(0,0,0,0.45); font-weight: bold; text-overflow: ellipsis; overflow: hidden; white-space: nowrap;}.revenue .name {color: #ccc;}.revenue .horizontal .metric {display: inline-block; padding-right: 1.5em;}.revenue .horizontal .name {padding-right: 0.5em;}.revenue .vertical .metric {display: block; line-height: 1.5em; margin-bottom: 0.5em;}.revenue .vertical .name, .revenue .vertical .value {display: block;}.revenue .square .metric, .revenue .button .metric {display: table-row;}.revenue .square .metric {line-height: 1.5em;}.revenue .square .name, .revenue .square .value, .revenue .button .value {display: table-cell;}.revenue .square .name {padding-right: 1.5em;}.revenue .button .name {display: block; margin-right: 0.5em; width: 1em; overflow: hidden; text-overflow: clip;}.revenue .button .name:first-letter {margin-right: 1.5em;}a.adslot-overlay:hover {border: 2px solid rgba(58,106,173,0.9);}a.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}a.adslot-overlay:hover .revenue {border-top: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}div.adslot-overlay:hover {cursor: not-allowed; border: 2px solid rgba(64,64,64,0.9);}div.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}div.adslot-overlay:hover .revenue {border-top: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}6_4_2012_11_48_48_am.jpgTurn The inner bit towards you until it goes in fully then turn it on and it might work. Thats what I did and it worked
1helpful
Toshiba Portege M780 - THe F10 light is on & the keyboard won't work. I have tried hitting Fn F10 to toggle but it does nothing.
Press the Fn-F10 combination to deactivate the overlay keyboard (numerical pad). The Fn key is the one to the right of the Left CTRL key.
Hi, I need some help here. My Aunt uses a Pronto M17 sure step with a Invacare controller that has Mk6ispj and W/pss written on it. The unit works fine but wont turn off and has trouble turning on as well....
The Mk6 spj w/pss has an overlay with buttons over the sensors. The functionality is very much like a microwave keypad. These buttons go bad over time and you can replace the overlay for under $20. When you press the buttons they contact some inductive sensors on a circuit board underneath which induces a current flow in the sensor. The pads flatten out over time and dirt, oil and food can accumulate under the pads between the pad and sensor. This causes decreased sensitivity and poor function of the buttons. You may be able to carefully remove the overlay and clean it and the underlying circuit board with spray electronic cleaner. This works for awhile, but I usually just replace the overlay. The new overlay comes with a new layer of adhesive. Hope this helps.
Oven beeps with f7 code , replaced display pcb . oven still beeps replaced front touch pad , now cooling fan comes on and after a while oven beeps with no error code . and blower fan button does not work ,...
hello,
(indication of problem)
This error code on a oven indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.comappliancepartspros.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hope this information helps you.
thank you for using fixya.
One of the buttons on my control pad is flat
It depends on if the issue is in the control board itself or just the overlay has become flat.A new control board would be part# WB27T10911 which is about 120.00. The overlay part number is WB27T10968 and retails for approx 85.
To replace either one you would have to remove the control panel and control board. The overlay will be glued to the control board. You could take a heat gun any heat the board up slightly to remove the overlay. Be sure not to let the board get too hot you dont want to damage any of the components on the board. Hope this helps.
Need clock overlay touch pad can't find compatible part
Hi, I can get you the overlay. It is about 30.00. It is black in color.
Vic
1helpful
Multiple paper feed with 5L
You need a separation pad kit for your machine. The parts are relatively inexpensive. There are 2 ways to accomplish the fix. You can install a separation pad overlay kit which can be done without disassembly which is simply adding a peice of rubber over the existing pad or a complete roller & pad kit which requires disassembly of the machine. The easiest is the overlay however best and longest fix is the full kit replacement. Here's a link to each of the kits off of ebay.
Overlay Kit: (5 minute install) Approx. $10.00
http://cgi.ebay.com/HP-Laserjet-5L-6L-3100-3150-Jam-Repair-Kit-Feed-Fix_W0QQitemZ230300272758QQcmdZViewItem?hash=item230300272758&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Full Feed Replacement Kit: (30 minute disassembly required) Approx. $25.00
http://cgi.ebay.com/HP-LASERJET-5L-6L-3100-FEED-JAM-REPAIR-KIT-VIDEO-8-PCS_W0QQitemZ120319146203QQcmdZViewItem?hash=item120319146203&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Here's a link to a fre service manual for the machine just in case you get into difficulties:
http://www.feedroller.com/Store/Service%20Manual/LASERJET%205L,%206L,%206L%20Gold,%206L%20Pro%20Service%20Manual.pdf
Hope that helps you. If so please rate me with a FIXYA!
3answers
Asus w2v laptop keyboard problem
wow thats just reversed i wthink its a new design
thank u
Touch pad not working
The oven control will need to be replace if proper voltage is there. May need to get overlay for control if it doesn't come as one piece.
Electronic Control Panel
If several options on the control pad do not work, I'm afraid you probably have an electronic control board that has gone bad. They aren't serviceable and have to be replaced. They can be a bit pricey, however. Most, run over a $100 with some running over $300. A lot of it depends on options and model. If you decide to replace the control board, the overlay (plastic piece with all the numbers printed on it) usually does not come with it, either. You can reuse the old overlay by carefully peeling it off the old control board and reapplying it to the new one. The overlay can run as much $30-$40 as well depending on where you get it. I hope you find this helpful.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
