Miscellaneous Logo
Nicolasa Heidelberg Posted on Sep 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many protons and neutrons and electrons in iodine
David Brown
Level 2:
Habit-Forming:
  • Expert 64 Answers
  • Posted on Oct 12, 2015
David Brown
Expert
Level 2:
Habit-Forming:
Answers
64
Questions
Helped
23635
Points
209
Iodine has an atomic weight of 126.9, comprised of 53 protons and 74 neutrons. It also has 53 electrons, because the number of electrons will always match the number of protons. The electrons are arranged in shells containing 2, 8, 18, 18, 7 electrons, totaling 53.
What is the basic of an atom
. Atoms are the basic units of matter and the defining structure of elements. ... We now know that atoms are made up of three particles: protons, neutrons and electrons - which are composed of even smaller particles such as quarks.
tip
Basic Electricity And Electronics
Remember
1. Almost Every System in a vehicle uses some type of electric or electronic component.
2. An Atom consists of small particles called protons, neutrons, and electrons.
3. Negatively Charged electrons circles around neutrons and protons
4. Current Abbreviated I is the flow of electrons through a conductor
5. Voltage abbreviated V Or E is the force that causes electron flow
6. Resistance abbreviated R is the opposition to current flow.
7. Ohms's Law is a simple formula for calculating volts,amps,or ohms when two of the three values are given.
8. If A Magnetic field is passed over a wire an electric current is generated in the wire.
9. When A switch is closed, a circuit is complete. When the switch is open, a circuit is broken and does not function.
10. A Fuse Protects a circuit against damage caused by a short circuit.
What is isotope?
An isotope of an element is a molecule of that element having an extra neutron or two tacked on, but the same number of protons and electrons as in the basic element.
The most mundane example would be deuterium, or 'heavy water', which has a molecule with 2 Hydrogen atoms, 1 oxygen, as normal, and extra, one neutron.
Many many elements can have molecules which are isotopes of the basic formation. Carbon and Uranium are 2 of the common examples.
2answers
What are the structure of atoms
depends on which element.
Aug 15, 2016 • Optics
How are protons organized ?
Atomic protons? The nucleus of the atom of each stable element has a certain number of protons, and except for hydrogen, also neutrons. These numbers are what differentiate the elements and give them properties, whether gaseous, metallic, alkaline, reactive or inert. Protons have a positive electrical charge.
The number of electrons will match the number of protons to give a stable atom a neutral net charge. An atom which loses or gains an electron or 2 is known as an ion. An atom which gains one or more neutrons is known as an isotope. However ions and isotopes still have their proper numbers of protons.
Ions will seek to attach to another particle so as to gain stability. Isotopes will decay over time, sometimes thousands of years.
All the elements are arranged in families or groups where chemical properties are comparable, in the Periodic Table of the Elements
https://theapevine.files.wordpress.com/2012/04/periodic-table.png
List the three subatomic particles
There are many more than three subatomic particles. The "classical" three are the proton, neutron, and electron. You may read more here.
The nucleus of an atom contains _________. a.
It contains "Protons and Neutrons" so the solution for your question is "C".
Good luck.
Thanks for using FixYa.
2answers
Which particle is the hightes in the following
Protons have a +1 charge. This is the same magnitude of an electron but an electron has a −1 charge. Neutrons have a 0 or no charge.
The following Wiki Article explains the process of Proton decay
Main article: Proton decay Protons are observed to be stable and their theoretical minimum half-life is 1036 years. Grand unified theories generally predict that proton decay should take place, although experiments so far have only resulted in a lower limit of 1035 years for the proton's lifetime. In other words, proton decay has never been witnessed and the experimental lower bound on the mean proton lifetime (2.1×1029 years) is put by the Sudbury Neutrino Observatory.[5]
However, protons are known to transform into neutrons through the process of electron capture. "When a high energy-proton collides with an atom, it causes the ejection of an electron from the outer layer of the atom."[6]:125 This process does not occur spontaneously but only when energy is supplied. The equation is:
1a11b43084f71df3683387ac7281c27b.png where
p is a proton, e is an electron, n is a neutron, and νe is an electron neutrino The process is reversible: neutrons can convert back to protons through beta decay, a common form of radioactive decay. In fact, a free neutron decays this way with a mean lifetime of about 15 minutes.
1helpful
2answers
How do atom the smallest particles of matter form
The current view is that atoms are made up of protons and neutrons (which in turn are made up of quarks and gluons) and electrons. The protons and neutrons are at the central core called the nucleus, and the electrons revolve around it, being held in orbit by the electromagnetic force between the negatively charged electrons and the positively charged protons in the central nucleus. It is very much like the solar system with the sun at the center and the planets revolving around it. They were formed right after the "Big Bang" when our known universe originated from pure energy some billions of years ago. The energy was converted to the elementary particles (quarks, gluons, leptons etc...) from which protons and neutrons were formed. From these, atoms of different elements were produced.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Top Miscellaneous Experts
Mike Lann
Mike Lann
Renee Knafel-Bullock
ricebike
Are you a Miscellaneous Expert? Answer questions, earn points and help others
