20 Most Recent MPS Multimedia QuickStudy Chemistry for PC Questions & Answers
4answers
Why is it necessary study chemistry?
Chemistry is very important although it may not be something immediately important in your life.
The knowledge you gain slowly through school and university is amazing.
Without knowing chemistry you may not know what those chemicals listed in the ingredients in your food are. You may in the future mix house hold chemicals and get something dangerous, this has happened in the past, and when it does happen you wouldn't know how to best protect yourself.
Chemistry works hand in hand with everything from biology to what your using in your house, everything including plastics (organic chemistry).
Once again the chances of you using something like hybridization is everyday life is very unlikely however the little things you learn can help immensely.
Thanks for using Fixya.
Rating the solution is highly appreciated
8/3/2022 7:49:21 AM • MPS Multimedia... • Answered on Aug 03, 2022
2answers
Soduim + iodine
i think its 7...
"7.) calcium oxide + diphosphorus decaoxide"
that causes the problem - stop drinking it with empty stomach...
1/11/2011 11:54:03 AM • MPS Multimedia... • Answered on Jan 11, 2011
Estimate the bond energy' S-F' in SF6.the standard
What is the S-F bond energy in SF6 given DHfo for each of the reaction components? For this problem you must first calculate the change in enthalpy (heat transfer, delta H under standard conditions) for the conversion, S(g) + 6F(g) => SF6(g) OR for the reverse reaction, it really doesn't matter, because the numerical value will be the same, regardless. Once you calculate the heat transferred, you will be able to say that the amount of heat transferred was the amount of potential energy trapped in all of the S-F bonds, all six of them in the molecule. So, to obtain the answer asked for (the energy content on one S-F bond), all you will have to do is divide by 6. The above is a logical approach, because all six of the S-F bonds are identical. This is so, because, according to VSEPR theory (look it up for more background on that, if you are interested), you can predict that its molecular geometry is "octahedral" with the central sulfur atom having "sp3d2 hybridization." Here is how you set up the problem: First write the balanced chemical equation with the given heats of formation (in kJ) written under each of the reaction components: S(g) + 6F(g) => SF6(g) 275 6(80.) -1100. Note: I am assuming that each of the above quanties is good (i.e., known) to at least the unit's place; that is, + or - 1 kJ. This reasonable assumption allows me to unambiguously indicate the number of sig figs in each quantity - an important consideration for proper rounding off of the final answer. Recall that the sum of the product values minus the sum of the reactant values, each component multiplied by its corresponding coefficient will give the net enthalpy ("reaction enthalpy") of the reaction as written. In this case, there being only one product, the reaction enthalpy is: -1100 - (480 + 275) = - 1855 kJ. From this, we can see that as S and six Fs are combined, 1,855 kJ of heat are released into the surroundings (that is, an exothermic reaction). The amount of heat released informs you of the combined bond energy of ALL six S-F bonds. A good rule to remember: As bonds are formed, energy is always released (an exothermic process). As bonds are broken (as in the reverse reaction), the same amount of energy is being absorbed (an endothermic process). Therefore, in conclusion, one S-F bond has a bond energy of 309.17, which is more properly rounded off to 309 kJ. Recall that the rule for rounding off when adding or subtracting is to make sure that the final answer has the same precision as the values used to calculate it. Since each given value was good only only to the last unit
1/5/2011 6:50:27 AM • MPS Multimedia... • Answered on Jan 05, 2011
Why are carbon and its compounds used as fuels for
Most carbon compounds that are used for fuels belong to the category of "organic" compounds called "hydrocarbons (HCs)," which, historically, at least, are plentiful and harvested from ancient petroleum deposits by the big oil companies - the raw oil being easily fractionated at processing plants to produce a great variety of different organic compounds from the most volatile (gases, such as CH4, methane; C2H6, ethane; C3H8, propane, etc) to an extensive series of progressively higher boiling liquids (C4H10, butane; C5H12, pentane; C6H14, hexane; C7H16, heptane; C8H18, octane; etc. Our gasoline is usually a complex mixture of these hydrocarbons, in the range between 3 and 12 carbons.
They are a traditional favorite for fuels because they can be stored in condensed form and transported long distances via truck or a complex underground system of pipes; and because they burn cleanly in the presence of sufficient oxygen to give only carbon dioxide (CO2, not classified as an organic compound) and water (H2O), each of which may be trapped and recycled in industrial processes. Another big plus for the use of HCs is that all of their reactions in the presence of oxygen are "exothermic"; that is, as they burn heat is always produced, which can be use to heat our homes and provide the energy needed to run our machines, such as our cars and trucks and jets.
1/5/2011 4:15:16 AM • MPS Multimedia... • Answered on Jan 05, 2011
In a 1.5% lidocaine solution, how many grams of
Hello, I can help you if you include more data in your question.
As an organic compound, lidocaine is insoluble in water, so I am assuming that either some combination of water and alcohol (ethanol), or a pure organic solvent like ethanol or diethyl ether is being used.
If lidocaine were soluble in water (which it's not), you would have been able to solve your problem as indicated below. Maybe you would be able to modify the indicated solution by taking into consideration the density of the organic solvent.
Percentage (%) by mass is one of the common ways to express the concentrations of solutions.
Since % means the number of grams of solute in 100 grams of solution (solute + solvent), a 1.5% solution of any solute refers to 1.5 grams of it in 100 grams of solution.
Assuming we are referring to an aqueous solution (that is, where water is the solvent), this reasonably approximates to 1.5 grams of lidocaine per 100 mL solution. We can assume this result, because we have a dilute watery solution, which probably has the density close to the density of pure water, which is 1.0 gram per 1.0 mL at commonly used temperatures, such as average room temperature.
So, 1.5 g lidocaine per 100 mL solution can easily be scaled down by one-tenth to give:
0.15 g lidocaine per 10 mL solution.
1/4/2011 11:53:48 AM • MPS Multimedia... • Answered on Jan 04, 2011
I need list of australian universities that award
Access Google Australia: http://www.google.com.au
and enter "australian university petroleum chemistry"
and do a search.
9/27/2010 4:40:14 PM • MPS Multimedia... • Answered on Sep 27, 2010
Express kelvin zero in degree celsius?
0 degree K is equal to -273.15 degree C
6/26/2010 6:54:31 AM • MPS Multimedia... • Answered on Jun 26, 2010
What is science?
science is the well organized intelligence about every thing .
6/17/2010 6:53:12 PM • MPS Multimedia... • Answered on Jun 17, 2010
What is conservation of mass and energy and give
In fact there are 2 different conservation laws: conservation of mass and conservation of energy. Of course in a chemical or any other physical process these 2 laws will hold!
Conservation of mass: the mass of a closed (isolated system) system will remain constant over time.
Conservation of energy: total amount of energy in an closed system remains constant over time
Furthermore if we look into the relativity theory, it states that in fact mass and energy are two names for the same thing (the equivalence principle of mass and energy), neither one "appears" without the other.
Example: an iron nail left in a cup of water until it turns entirely to rust. A precise scale will register a change in mass. The energy will appear as heat, which will be lost to the environment so because of the conservation law you will see a loss in the mass of the system.
4/20/2010 11:37:13 AM • MPS Multimedia... • Answered on Apr 20, 2010
What is the difference of conservation of mass and energy
The law of conservation of mass and energy states that mass and energy can neighther be created nor destroyed however it can be changed into one form to another.
3/11/2010 12:30:20 PM • MPS Multimedia... • Answered on Mar 11, 2010
2answers
Which particle is the hightes in the following
Protons have a +1 charge. This is the same magnitude of an electron but an electron has a −1 charge. Neutrons have a 0 or no charge.
The following Wiki Article explains the process of Proton decay
Main article: Proton decay Protons are observed to be stable and their theoretical minimum half-life is 1036 years. Grand unified theories generally predict that proton decay should take place, although experiments so far have only resulted in a lower limit of 1035 years for the proton's lifetime. In other words, proton decay has never been witnessed and the experimental lower bound on the mean proton lifetime (2.1×1029 years) is put by the Sudbury Neutrino Observatory.[5]
However, protons are known to transform into neutrons through the process of electron capture. "When a high energy-proton collides with an atom, it causes the ejection of an electron from the outer layer of the atom."[6]:125 This process does not occur spontaneously but only when energy is supplied. The equation is:
1a11b43084f71df3683387ac7281c27b.png where
p is a proton, e is an electron, n is a neutron, and νe is an electron neutrino The process is reversible: neutrons can convert back to protons through beta decay, a common form of radioactive decay. In fact, a free neutron decays this way with a mean lifetime of about 15 minutes.
10/16/2009 10:32:23 AM • MPS Multimedia... • Answered on Oct 16, 2009
2answers
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered 6 hours ago
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/15/2024 4:17:35 AM • Computers &... • Answered Yesterday
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered 3 days ago
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered 3 days ago
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered 3 days ago
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
MPS Multimedia QuickStudy Chemistry for PC Logo
12 questions posted
Top MPS Multimedia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MPS Multimedia Computer and Internet Expert? Answer questions, earn points and help others
