Location of brushes on dremel multi max kit
There should be a second brush. Look along the motor - you're looking for a spot where the armature (the part that rotates) is surrounded by a ring of little straight copper-colored bars. That's the "commutator" section. The brushes run against the copper bars.
Look on the outside of the plastic shell - there may be two large plastic screws, one on the outside of each shell half, right about where the commutator would be on the inside. Those are your brush holder screws; you should be able to change the brushes from OUTSIDE the tool without opening it. Some tools are built without external brush holders like that, but most have external brush holders.
If you find external brush holder screws, then track down the second brush and set it aside. It MAY be hanging from the brush holder in one of the shell halves. Unscrew both brush holders and remove them from the shell. Set them aside and reassemble the motor back into the shell. If the brushes are really short, like if they're nearly cube-shaped, then it's time to replace them. If not, try them again.
Insert one brush into each of the holes the brush holder screws came out of, and put the brush holder screws back in. Be careful not to cross-thread them. Try the tool.
If it still won't run, it's possible that an armature winding has given up the ghost and it's time to replace the tool...
