Garden Logo
K
Kevin Posted on Aug 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Claude Kayser
Level 3:
Top Expert:
  • Craftsman Master 9,098 Answers
  • Posted on Aug 11, 2015
Claude Kayser
Craftsman Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5068022
Points
28436
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
2answers
What size belt replacement for Sears 2000 Cub Cadet deck belt model SV 590?
The SV 590 is the model designation of the Kohler engine powering the lawn tractor.
https://www.google.com/search?q=kohler+model+sv590s+parts+diagram
The 'Sears 2000 Cub Cadet' part is most of your tractor model details and the Deck Belt appears to be 42".
https://www.google.com/search?q=Sears+2000+Cub+Cadet+deck+belt
2helpful
2answers
Belt smoking
I just had a problem with my belts smoking also. Replaced belt and the same thing happened. Removed deck, flipped it over and their it was. I large stick had somehow gotten wedged between one of the blades and the deck frame, causing the belt to turn but the mandrel would not. Removed the stick and problem solved. I don't know if your problem will be solved as easily as mine but for me it was just a reminder to ALWAYS check the simple things (and normally the ones that doesn't cost) first and you may be surprised.
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
1helpful
Find replacement belt for LT 2000 17.5 HP Kohler Engine
WHICH BELT ARE YOU LOOKING FOR A LOT OF AUTO PARTS STORES WILL GET THEM FOR YOU OR ORDER ONLINE. GET THE MAKE AND MODEL AND SERIAL FROM TRACTOR , BELTS SRE NOT HARD TO FIND
Yard Man 42'' Drive Belt Install
it is a mtd mower ,however you should be able to go to a tractor supply store with the decksize and the engine size and get the proper belt.AGAIN(TSC) store,OR TSC.COM HOPE THIS HELPS
Jun 08, 2009 • Mtd Garden
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
