Question about Proton Televison & Video
How to connect my proton pltv-32c to dicect tv box?
SOURCE:
SOURCE: Proton pltv 32C
1080i or itll do 720p
Posted on Oct 05, 2008
Fame_Guru
  • 483 Answers
SOURCE: need remote control code for Proton PLTV-32c for comcast remote
Hey,
You can use this E-book to program your remote.
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_on_demand_remote_manual.pdf
Many Thanks
Fame !
Posted on May 07, 2009
micromatikal
  • 2777 Answers
SOURCE: proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Posted on Oct 13, 2010
budmrtn
  • 11361 Answers
SOURCE: PLTV-32C does it not have
It does use F connector for the coaxial cable connections.
Boards inside your TV:
http://www.shopjimmy.com/catalogsearch/result/?q=PLTV-32
Tuner/main board picture with the connector shown.
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj9711027e00000.jpg
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Jan 20, 2011
  • 718 Answers
SOURCE: we own a proton pltv-32c.
Check the FORMAT option in the OSD (on screen display) menu. It may need to change.
It's on page 15 of the User's Manual.
Format
Controls the picture format. The options are 4:3 and Full
(16:9-widescreen).
Or you could reset the tv by using the All Reset button on the menu.
All Reset
Resets all options to factory-default settings.
See page 23 of the User's Manual.
You can get a user manual from;
http://imageuploads.googlecode.com/files/PLTV-32C-owners-manual.pdf
If you do not have Adobe Reader to read the manual you can get it from;
http://get.adobe.com/reader/
Posted on Mar 28, 2011
Where I can buy a Remote Control for Protron TV 32
Setup code to check with Proton TV is 1288. If you wish to get more detail about which brand remote control have setup codes to Proton TVs, check these sites. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'. Locate the exact model remote control, and buy than one according to availability. Many brands will have setup codes. Check all of them.
Aug 21, 2013 | Protron PLTV-32C LCD TV
We own a proton pltv-32c. the image coming in is larger than our screen (or the ratio is off). Basically the top and bottom of all images are being cut off (same for TV and video watching). What to do?
Format
(16:9-widescreen).
All Reset
Mar 27, 2011 | Televison & Video
PLTV-32C does it not have a basic coaxial connection for cable tv without the box or for an antennae?
Jan 18, 2011 | Protron PLTV-32 Television
Need code to operate a sony dvd player connected to my protron tv
The code for the Sony DVD player is
0533, 1533, 0864, 1070 choose one of the code they are all for Sony DVD player .
Dec 28, 2010 | Protron PLTV-32C LCD TV
Proton pltv-26 sound works but no picture
If you have PLTV-32, check to see if your AC adapter is putting out the 24vdc for the backlight inverter, you are getting the 12vdc from the adapter for the sound and for the processor to turn on the TV, otherwise you may have backlight inverter board problems.
http://www.lcdpayless.com/productpage.php?productId=6332
PLTV-32C has power supply module inside the TV: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv-32+power+supply&um=1&ie=UTF-8&ei=PWVvTOy6M5H4swOciO3DCw&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCwQrQQwAw
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Aug 20, 2010 | Protron PLTV-32 Television
Proton pltv 32C
Oct 05, 2008 | Protron PLTV-32 Television
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Hooking cable to tv
I have a protron tv and unable to hook the cable box staight to the tv. what am I missing.
Jun 14, 2008 | Protron PLTV-32 Television
Televison & Video Logo
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
