20 Most Recent Protron PLTV-32C LCD TV Questions & Answers
Where is the cable connection on back of tv
It is the threaded input on the right side of the rear of the chassis labeled ANT
12/29/2014 6:52:38 AM • Protron PLTV-32C... • Answered on Dec 29, 2014
Where I can buy a Remote Control for Protron TV 32
Setup code to check with Proton TV is 1288. If you wish to get more detail about which brand remote control have setup codes to Proton TVs, check these sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'. Locate the exact model remote control, and buy than one according to availability. Many brands will have setup codes. Check all of them.
8/22/2013 6:18:57 AM • Protron PLTV-32C... • Answered on Aug 22, 2013
I think I need a new remote control I ordered a new remote that I was told this was an alternate the original was no longer available I order a PLT 3250 remote should I have order a PLT 32 instead the
Have the first remote tested--most shops have a tester--point remote at it and press buttons and it reacts with a flash (the tester) and if remote tests good the problem could be with the remote receiver in the set
10/30/2012 1:16:26 AM • Protron PLTV-32C... • Answered on Oct 30, 2012
I need help mi tv wong work after a energy went off
HelloJust unplug the tV from AC mains wall socket and leave it for at leat 10 minutes. This must reset its memory. Replug it back and see whether it helps you. If not the power inverter board [SMPS] should be repalced.This is the picture of the power supply board to your tV. OK.12_18_2011_1_43_22_pm.jpg
12/18/2011 1:43:59 PM • Protron PLTV-32C... • Answered on Dec 18, 2011
Sound problem
Hi, This problem is caused by an open resistor the main board 10 ohms value. It is located on the top of the module, is a very small and difficult to change. I recommend you, look for a TV shop to get help, otherwise you can buy the main board if you desire. This is the number of main board. Main Unit Number. 971-1069A-00 http://www.shopjimmy.com/auo-971-1069a-00-system-control-board.htm I'll be here for any further question.
8/18/2011 1:06:09 AM • Protron PLTV-32C... • Answered on Aug 18, 2011
I can't get any of my remotes to work with the
Possible that the codes do not match as required by the model of the TV.
Please check the links below for help:
remotecontrol codes: http://www.espares.co.uk/search/remote-controls/p/1090?utm_campaign=06-2011+unlimited+credit+1st&utm_medium=email&utm_source=emails ........ search for models of alltypes http://www.xdiv.com/remotes/ http://www.hifi-remote.com/ofa/codes-tv.shtml
6/20/2011 6:17:30 AM • Protron PLTV-32C... • Answered on Jun 20, 2011
I am lookinfg for a protron 32 lc tv model pds2315
Hello
Look on Ebay or Alibaba. Get ito this site;
www.epinions.com > Search
6/17/2011 3:30:04 PM • Protron PLTV-32C... • Answered on Jun 17, 2011
Need code to operate a sony dvd player connected
The code for the Sony DVD player is
0533, 1533, 0864, 1070 choose one of the code they are all for Sony DVD player .
12/28/2010 8:35:41 PM • Protron PLTV-32C... • Answered on Dec 28, 2010
When I turn TV on it turns right back off.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.Please post back what you find.
12/1/2010 5:56:57 AM • Protron PLTV-32C... • Answered on Dec 01, 2010
How do I attach my protron TV with a universal remote?
To attach your Proton TV with a universal remote, you will need to first program the remote to work with your TV. This can typically be done by following these steps:
  1. Locate the remote code for your TV in the manufacturer's instructions or online.
  2. Press and hold the "Program" or "Setup" button on your universal remote until the indicator light turns on.
  3. Use the remote's number pad to enter the code for your TV.
  4. Press the "Power" or "TV" button on the universal remote to see if it turns your TV on and off.
  5. If the TV does not turn on and off, repeat steps 2-4 using a different code for your TV.
12/10/2022 5:21:16 PM • Protron... • Answered on Dec 10, 2022
2answers
What is phone number for protron remotes
try google search
2/21/2021 6:03:03 PM • Protron... • Answered on Feb 21, 2021
What are the code for a protron dvd player?
I suggest you use the code search function found on any Universal remote. DVD player codes are not listed.
4/2/2019 12:46:37 AM • Protron... • Answered on Apr 02, 2019
0answers
Protron PLTV-32C LCD TV Logo
24 questions posted
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Protron Televison & Video
Most Popular Question
need code operate sony dvd player
  • Televison & Video
