I turn my garmin on and all it does is say loading maps
SOURCE: Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
SOURCE: Garmin Nuvi 260 maps loading
http://www.garmin.com/garmin/cms/site/us/support/
Hope this helps
SOURCE: Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
SOURCE: My Garmin shuts off in the loading maps screen
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
