Just remove the battery, wait 15 minutes and replace it. There is no calibration on home use scales because you would need a guaranteed calibration weight.
Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. Make sure the scale is on a flat, stable surface: Uneven or unstable surfaces can affect the accuracy of the readings. Place the scale on a hard, level floor and ensure it is not wobbling.
2. Check the battery installation: Double-check that the new batteries are inserted correctly, following the polarity markings inside the battery compartment. Ensure there is good contact between the batteries and the terminals.
3. Calibrate the scale: Some digital scales require calibration after battery replacement or when experiencing issues. Check the user manual for instructions on how to calibrate your specific model. Calibration usually involves placing a known weight on the scale and adjusting it accordingly.
4. Clean the scale: Dirt, dust, or debris on the scale's surface or sensors can interfere with accurate readings. Use a soft, slightly damp cloth to clean the scale, ensuring it is dry before use.
5. Try weighing yourself multiple times: Step on and off the scale a few times to see if the error persists. This can help determine if the issue is consistent or intermittent.
To use a scale, first you'll need to make sure it is properly set up and calibrated. This typically involves placing the scale on a flat, stable surface and pressing a "tare" or "zero" button to reset the scale to 0. If the scale is battery-operated, you'll need to install the batteries according to the manufacturer's instructions.
To use the scale, simply place the object you want to weigh on the surface of the scale. The scale should display the weight of the object in the units you have selected (usually pounds or kilograms).
To clean the scale, you should use a damp cloth or sponge to wipe down the surface of the scale. Be sure to avoid getting any water inside the scale itself.
To calibrate the scale, you may need to adjust the scale's settings or follow a specific calibration process according to the manufacturer's instructions. This may involve using a known weight or adjusting the scale's "zero" point. Calibrating your scale can help ensure that it is providing accurate readings.
To calibrate a digital scale, you will need to follow these steps:
Find a weight that you know the exact weight of, such as a coin or a small weight. This weight will be used to calibrate the scale.
Place the weight on the scale and wait for the scale to stabilize.
Check the weight displayed on the scale. If it is not accurate, use the scale's calibration function to adjust the scale to the correct weight.
To calibrate the scale using the calibration function, follow the instructions in the user manual for your specific scale. The process may vary depending on the make and model of the scale.
Once the scale is calibrated, remove the weight and test the scale by weighing an object of known weight. If the scale displays the correct weight, the scale is properly calibrated. If the scale is still not accurate, you may need to repeat the calibration process or consult the user manual for further instructions.
I hope this helps! If you have any further questions, don't hesitate to ask.
I don't have a manual. The readout is in kilos rather than pounds some of the time. How can I get it to read in pounds all the time? Also I replaced the batteries. Are they supose to be both with + up? I have a replacement heart valve so I don't want to know body fat. How do I make sure it is off?
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
My Weight Watchers digital scales model#ww39 has gone haywire. I put new batteries in it to no avail. You tap it and the numbers come right up then changes to 000.0 as it should, when you step on the scales the numbers flash as they should but either they weight you about 100lbs to heavy or the numbers continue to blink and the LCD goes blank. Can they be fixed? Can I fix them myself at home? Do I need to shoot them? Just throw them out in the yard? Please I need help!!
