hold the power button down for about 3 seconds- that should either 1. put it into pair mode (red + blue), or 2. Shut it down so you can retry pairing/turning them on.
Be sure the the headset in in 'Pairing' mode. When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Here is the problem, what most of the people do with this LG HBM 550 is press the PWR/END button on the headsent and when the headset light turn on Blue they let the button go and try to pair the device, this is worng when light is flshing Blue only it is not in the pairing mode.
You need to press and hold the button on the head set for five second and when the light flicker red and blue alternately, now device is in the paring mode.
Using you phone when to pair this device it might ask, depending on you r phone setting for the PIN or pass code which will be "0000"
Try ,,good luck
Regards
Chinmay
anyone have any ideas to help here
where is the battery
