20 Most Recent LG HBM-550 Wireless Headset Questions & Answers
My headset continuously makes a beeping noise
seems the battery is defective and not charging correctly anymore. a local service might can replace battery. check costs before get it repaired, so you can decide worth or not.
4/26/2014 5:20:12 PM • LG HBM-550... • Answered on Apr 26, 2014
0answers
Lg hbm 550
Be the first to answer 2/17/2013 3:16:18 AM • LG HBM-550... • Posted on Feb 17, 2013Be the first to answer
0answers
0answers
Will not charge
Be the first to answer 1/22/2012 7:14:48 PM • LG HBM-550... • Posted on Jan 22, 2012Be the first to answer
0answers
3answers
LG HBM 550 with Chocolate
Here is the problem, what most of the people do with this LG HBM 550 is press the PWR/END button on the headsent and when the headset light turn on Blue they let the button go and try to pair the device, this is worng when light is flshing Blue only it is not in the pairing mode.
You need to press and hold the button on the head set for five second and when the light flicker red and blue alternately, now device is in the paring mode.
Using you phone when to pair this device it might ask, depending on you r phone setting for the PIN or pass code which will be "0000"
Try ,,good luck
Regards
Chinmay
4/3/2011 1:44:59 AM • LG HBM-550... • Answered on Apr 03, 2011
2answers
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
3/12/2011 4:36:02 PM • LG HBM-550... • Answered on Mar 12, 2011
LG default password
My iphone 4 was asking for my pin number using LG-HBM 900, I used 0000 and it paired okay.
2/5/2011 7:30:01 PM • LG HBM-550... • Answered on Feb 05, 2011
My wireless headset will not
If you have followed the directions with the manual. And have exhausted all direction from the manual. I'm sorry but i would return it.
12/26/2010 6:27:56 PM • LG HBM-550... • Answered on Dec 26, 2010
Pairing to new number
hold the button on the headset until it is on paring mode, then let your phone search for it. when it is found it will ask for the password it should be 0000 i you haven't changed it
12/14/2010 3:51:58 AM • LG HBM-550... • Answered on Dec 14, 2010
My bluetooth device is asking
often the default pin is 0000 e.g. 4 zeros. i think this is the same for this device.
i hope this was useful.
12/12/2010 12:05:57 AM • LG HBM-550... • Answered on Dec 12, 2010
I am looking for the pairing code for my LG
Most use a basic default PIN such as “0000”, “1111”, or “1234”.
7/27/2010 2:39:06 PM • LG HBM-550... • Answered on Jul 27, 2010
I don't get to connect to my nokia n97 mini
With your headset intitially turned off, press and hold the PWR/END button for some 5 seconds, until the indicator light flashes alternately in red and blue. It is now in pairing mode. Then, on your phone go to 'Menu > Settings and Connectivity > Bluetooth > Options > New paired device'. After a little while, your headset should appear.on the phone screen. Select it, and enter '0000' (four zeros) as passkey. Once the paring procedure is complete, your headset should enter the stand-by mode. You just have to pair any two bluetooth enabled devices once. All subsequent connections should be done provided that both devices are close enough to each other.
Hope it works for you.
Regards, Carlos
6/4/2010 3:28:44 PM • LG HBM-550... • Answered on Jun 04, 2010
How can i get the passkey to connect with my phone
try to type in random codes that u use for anythin from ipod lock code to birthdays to special holidays like aniverseries or just reallyany code that u think will work
3/8/2010 5:24:37 AM • LG HBM-550... • Answered on Mar 08, 2010
3answers
How to reset lg hbm - 550 bluetooth headset
If you look in the manual in the link give by jeffsgirl903 it says "When asked for the Pass/PIN code during the pairing procedure,
please enter “0000” (4Zeros)."
2/12/2010 3:53:14 PM • LG HBM-550... • Answered on Feb 12, 2010
How to reset passcode for LG HBM-550
The passkey is 0000 (Four Zeros)
Here's the manual:
http://www.megaaccy.com/HBM_550.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
2/6/2010 4:41:57 PM • LG HBM-550... • Answered on Feb 06, 2010
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
12/9/2009 8:50:23 PM • LG HBM-550... • Answered on Dec 09, 2009
LG HBM-550 Wireless Headset Logo
Popular Tags
47 questions posted
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • LG Radio Communications
Most Popular Question
lg hbm 550 chocolate
  • Radio Communications
