20 Most Recent Blueant Blue Ant 091193 Supertooth II Hands-Free Bluetooth Speaker Wireless Headset Questions & Answers
Can not pair Samsung S4 to BlueAnt
You type the password 3 time after that they will ask you for your puk code then check from your back sim card and after that new password is 1234 to get out Ok .
8/16/2014 5:08:05 AM • Blueant Blue Ant... • Answered on Aug 16, 2014
6answers
Blue Ant ST3 will not recognize 0000 passcode.
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
1/30/2014 1:03:32 AM • Blueant Blue Ant... • Answered on Jan 30, 2014
Which kind of cake will ants eat faster
i already answered this :)
10/18/2013 3:34:46 AM • Blueant Blue Ant... • Answered on Oct 18, 2013
Can't pair blueant bluetooth with iphone 4s
Open the device's microphone, ensue it is NOT on charge, hold the answer button and the silver flat button (hidden by mic when closed) and it should work
7/22/2013 8:20:41 AM • Blueant Blue Ant... • Answered on Jul 22, 2013
2answers
Just got a new verizon cell phone..and it cannot
your phone and your headset may not be compatible, you can always call bluetooth or verizon to find out. Bluetooth: 877-668-6258
verizon: 800-922-0204
10/8/2012 4:01:20 PM • Blueant Blue Ant... • Answered on Oct 08, 2012
I need to connect my nokia 2630
Turn on the bluetooth and select "Add New Device". Keep the button on your bluetooth headset pressed until the mobile searches the bluetooth headset.
12/16/2011 8:19:37 AM • Blueant Blue Ant... • Answered on Dec 16, 2011
Won't charge or switch on. Does nothing at
This is usually because the battery has totally failed, take the thing apart, difficult, but not impossible, and you have nothing to loose, and superglue is great, get the battery and find a replacement, that's about all one can do. Otherwise it's replacement time sorry.
10/20/2011 2:38:41 AM • Blueant Blue Ant... • Answered on Oct 20, 2011
2answers
Hi, have had my blueant
Hi, well i see this type of thing a lot. You see it is like this, ALL manufacturers have what we call a "Golden List" :now on this list are ALL of the headsets that will work 100% with their phone.
Now if it isn't on this list then it may or may not work, most likely it will NOT.
Accordingly you need to check this out and see if indeed your headset will indeed work with that particular phone?
When it all works as it should it is almost too hard to stop them working together, whenever they won't pair it is, 9 times out of 10, an incompatibility, or the unit is faulty,it really is that simple..
The fix, well, it is to get one from, you guessed it, the "Golden list" Then it is guaranteed to work.
7/4/2011 1:40:58 AM • Blueant Blue Ant... • Answered on Jul 04, 2011
2answers
What is connection code for BlueAnt ST3
Pin code is 0000, make sure the device is in pair mode first
6/26/2011 9:08:15 AM • Blueant Blue Ant... • Answered on Jun 26, 2011
Trying to pair up my
You could try the bluetooth generic passwords (0000 and 1234), these usually work with most devices.
5/3/2011 5:08:05 PM • Blueant Blue Ant... • Answered on May 03, 2011
I have a blueant bluetooth and i forgot the
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
5/1/2011 6:21:33 AM • Blueant Blue Ant... • Answered on May 01, 2011
I have a Blue Ant ST3 and I can't pair it with my
i cant pair my iphone 4 with blueant supertooth
3/23/2011 7:01:10 AM • Blueant Blue Ant... • Answered on Mar 23, 2011
3answers
My g3 iphone says blue ant st3 password incorrect
Hi - I had the same problem setting up my 3G S. Here's the solution. In "Settings/General" set the Bluetooth to "ON". Turn your ST3 OFF by holding the green button until she says it's Powering Down. Now press and hold the green button ON until Language Selection (British English) option. Select language by pressing green button again. Next she will say "Device Found-Paring Successful-Enter password 0000". Enter 0000 and your phonebook will start downloading. There ya go!
12/19/2010 5:29:20 AM • Blueant Blue Ant... • Answered on Dec 19, 2010
0answers
I have recently got a
Darrell 12/11/2010. make sure you have the phone set to sync then press green button on ST3 until it ask what language you require keep it pressed until it states on the screen that you want to sync press ok and you will find that it has connected. You can use the same system to sync it to an I Phone as well
11/12/2010 5:07:44 AM • Blueant Blue Ant... • Answered on Nov 12, 2010
Blueant Blue Ant 091193 Supertooth II Hands-Free Bluetooth Speaker Wireless Headset Logo
Popular Tags
79 questions posted
Top Blueant Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Blueant Radio Communications
Most Popular Question
blue ant st3 will not recognize 0000
  • Radio Communications
