It does greatly depend on the shape of the crystal. If it is an unusual shape, this would need a very skilled person to shape it correctly. If it is a regular round shape, these are easier to come by. This UK web site [link in blue] offers watch parts including crystals to give you an idea on prices. I use a vernier to measure the diameter and thickness of the crystal I wish to replace and UV activated glue to fix the replacement crystal in place and one of those UV nail lamps to cure the glue. This should be done in a clean environment and I use finger cots to prevent fingerprints. The whole process takes about 30 to 60 minutes. Any _competant_ watch repair place should be able to help you. At least you know the process now :)
Acrylic Watch Glasses Tension Rings Flat Top High and Low Dome
SOURCE: Casio GW300 (2608) battery replacement
Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
Here is a site that has good instructions on how to change the battery in your G-Shock watch.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
SOURCE: Fossil Watch Repair,crystal replacement Fossil TM7221
See SuisseWatchService.com for watch crystal replacement in the USA.
SOURCE: Glass that covers the face of the watch is shattered-$ to replace
I am not sure about prices in US, but over here in England we charge £15 - £25 for mineral glass (depending on size, thickness, e.t.c.) and £50 - £120 for sapphire glass. As for today: £1 = 1.60$. Doesn't matter how you name it - glass or crystal, both are right.
SOURCE: My 433lsl black band broke. I can not find a replacement broke
order a replacement band directly from skagen its only $25
http://www.skagen.com/service/home.fx
Place the watch face-down on a clean towel to protect the crystal.
Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
Take the battery with you to a watch shop or electronics store to buy a replacement.
Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
