20 Most Recent
gossip Rectangle Case Leather Strap Watch Questions & Answers
Need bands
try the gossip web site or google it you mite get some on ebay. hope this helps joe
The crystal is broken.
Thank you for contacting FIxYa.
You should be able to have any local watchmaker fix the crystal. It is a very simple procedure but if you cant find a local, here is a suggestion:
http://www.crystalfit.com/
Best regards. Jewel
Broken crystal
Very common! Did you change the battery yourself? This is why I always suggest people take their watches to a reputable watch repair shop! You would be paying for a battery and not a new crystal! :-) You should be able to take it to a shop and have it replaced...although rectangle crystals can be tricky to find for exact fit!
Need to shorten a band
you better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
My pin to change the
the pin is called spring bars, you can find it to any watch service center. not only from the store that you have had purchased it.
i hope this will help you.
Gossip watch (QVC Item #J144887)
Unfortunately, Gossip watches are very poorly made and not intended to be serviced. However, a good watchmaker might be able to put it back together if you have the parts. Unfortunately, the watchmaker services will probably cost more than a new watch.
The only caveat I see is that many Gossip watches come with a 3-5 year warranty. There should have been a warranty card in the box when you got it. If not, QVC should be able to look up the warranty info for you. If not, go to JCPenny, Macy's or another retailer, open the box of one on display and copy down the warranty info.
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
