SOURCE: My Bunn coffee maker is leaking water
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
SOURCE: Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
SOURCE: Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
