20 Most Recent
Bunn-O-Matic Coffee Brewer GRW8 Questions & Answers
How to adjust the timer
Good morning to youIf the timer is electronic; hold down the set/mode button while you adjust the timer. If the time is adjusted by hand turn it the desired distance. OK in both instances.enjoy your coffeeKolbrun.
The pot is leaking water. We tried putting a new
You need to see where it is leaking from because it may not be from the tank. If there is a overfloe cup and there is water in it the machine may be overheating. It may also be and inlet solenoid sticking open. Check if there is a overflow cup or if water is continuosly allowing water in. Hope this helps.
WWW.MidstateBeverage.com
What makes the water reservoir all of a sudden
This is usually caused by the thermostat allowed the machine to boil the water. We offer an out-of-warranty exchange to get a new machine. If you will call customer service at 800-352-2866, we will be happy to assist you in getting a new machine.
We are replacing the white plastic washer, but
The white neoprene piece from the seal kit is on the bottom, then place the metal washer in and the bolt on top of it. Then insert the black plastic piece on top and insert into the sump area and tighten it down with a screwdriver. If you need further assistance, please call customer service at 800-352-2866.
Coffee maker leaks
Please contact customer service and a seal kit can be sent to you that should fix your leak-it is successful about 90-95% of the time.
Cooffe brews on its own
Hello. Here is what could be happening. Your brew timer may be having a problem where it is re actuating on it's own, in which case it would need to be replaced, and re calibrated. The other possibility is that the start switch is making contact internally, and telling the brew timer to start again. Your unit does not show it having a level probe, so most likely it is not overflowing due to a flooding condition. After you brew, turn off the lower heat switch, this will remove power to the brew circuit, if the problem stops, then you know it is one of those 2 things, and I would try the start switch first, as it is a cheaper item to replace than the timer.
Here is a link to your brewer manual with part #'s etc..
http://www.bunnomatic.com/pdfs/commercial/manuals/10613.0000.pdf
Hope this helped, and thank you.
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
