. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code c2557 means
"ATDC Sensor abnormality".
It appears due to following reasons,
1-Imaging unit (Drum unit) parts life is expired,
2-Developer's life is expired,.
3-Developer tank is hard, gears of the unit are not
moving
For best results and smooth functioning of machine,
simply call your technical services representative and he will help you in this
matter.
OR
if you want
to do it yourself, you have to do this.
1-Press "UTILITY/COUNTER'
button on the machine's panel.
2-Now press "check details"
button. (appeared on the lcd screen)
3-Now press these buttons,
STOP+0+0+STOP+0+1
4-now press "Tech
representative choice" button on LCD screen.
5-now press "PRINTER"
button.
6-press "ATDC GAIN"
7-Now press the "c"
button to clear the value, after clearing the value enter new value by using
numeric pad.
Enter new value by adding 10 to the previous value.
For example if the previous value was 150 you have to
enter 160 now or 165.
8-Enter the new value and press the End button on the LCD screen and exit.
9-Now restart the machine..
