Fx-82es how do we separate digits with the help of comma. like 123,456,789. I have already tried Turn the calculator on.
GO TO Display setup screen
1 for DOT
2 for Comma
This calculator does not have a separator for thousands, millions, etc. This feature may have seemed to the designers to be unimportant in a scientific calculator. You can however change the decimal mark from the dot to the comma. To do that, press [SHIFT][Mode] to enter (Setup). Press the Arrow down. In new screen look for 5:Disp.
I don't know which particular calculator model you have, but for an HP-12C, the manual says the following: Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory - or after Continuous Memory is reset - the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display
a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [.] key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
Sorry but you cannot. You can change the decimal mark from dot to comma but you cannot have the calculator separate the digits between thousands (thousands separator).
Yes,it's possible to program the Fx-82es to separate the digits with the help of comma. PLEASE FOLLOW THE INSTRUCTION CAREFULLY. If you make a mistake then please turn the calculator off and start over again. ==== Turn the calculator on. GO TO Display setup screen Disp 1 You will has two options 1 for DOT (that's not what you want) 2 for Comma (please press 2 and enter/triangle pointing to the right) Please let me know are you able to get to setup mode and make the comma change on reply.
Decimal Point and Separator Symbols You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator. • To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below. Display the selection screen. (Disp) 1. Press the number key ( 1 or 2) that corresponds to the setting you want to use. 1(Dot): Period decimal point, comma separator 2(Comma): Comma decimal point, period separator
It depends on the purpose of your trying to get rid of the comma. If the decimal mark (radix mark) is the comma, you can change it to the dot. If you just do not want to have the 3-digit separator, maybe you should get used to it, or buy another calculator.
To switch the radix (decimal) mark Turn the calculator off, then press and hold down the [.] (dot) key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [ . ] key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
Hello, Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
