SOURCE: CD Player problem
Most DVD players that would not play a disc even with
a known good disc inside signifies that the llaser eye/lens is
not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should
this not be corrective, perhaps your best bet would be to seek the
services of a qualified professional such as those in a Service Center.
Alternately, your friendly neighborhood electronic shop should do just
fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
SOURCE: CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
SOURCE: Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
SOURCE: KOSS CD player will not read CD says '' no disc
you need to Clean the laser lines inside the cd player I can do that for you if you want me to
SOURCE: dn-s3500 cd stuck
The way to force an eject, is to turn off the deck for a few minutes. Then when you turn it back on, continuously keep pressing the eject
