20 Most Recent JVC KD-S5050 CD Player Questions & Answers
Proper color for jvc 320 to jvc ks-bta100 hookup
There are only 3 POWER cables to worry about and one 3.5 aux. BLACK, BLUE, AND BROWN. Tap existing connections. on back of harness and connect 3.5 aux to back on unit.
10/6/2014 2:16:01 PM • JVC KD-S5050 CD... • Answered on Oct 06, 2014
How to change the clock on my kd-s5050
Press and hold the Sel (Select button) for more than 2 seconds. Release the button when you see Clock H, Clock M, SCM Link or Level. Use the Up/Down arrows (on the right side of the panel) to navigate to the Clock H option. Use the +/- buttons (on the left side of the panel) to set the current hour. Using the Up/Down buttons to navigate to Clock M. Then use the +/- buttons again to the current minutes. Then press Sel again to exit the clock set mode. JVC has the manual for the KD-S5050 on their support site: http://support.jvc.com/consumer/product.jsp?modelId=MODL027124 . The direct link to the manual is http://resources.jvc.com/Resources/00/00/95/GET0171-001B.pdf . The procedure for setting the clock is on page 15. Note: you'll need Adobe Reader or a similar program to read or print the manual. I hope this helps. Cindy Wells
9/27/2014 3:19:44 AM • JVC KD-S5050 CD... • Answered on Sep 27, 2014
0answers
0answers
0answers
Hook up radio to jeep cherokee
buy a 12 volt lamp tester (like a screw driver)check the wires when car ignition switch is turned on ,connect the wire side of tester to metal ground of ur car which supposed to be negative and other side of tested pin to the wires jack of ur car which is for radio connection previously,find out 2 connection points which are positive terminals one lights when igni switch is turned on the other one is permanent power terminal.now there are three wires of ur new radio one is black which should be connected to ground or metal body of ur car negative terminla and yellow connected to permanet power terminal and red one should be connected to power turned on with the swith which is called switched power.now try to find out other four groups of terminal two for front speaker two for rear speaker each speaker has two wires ,can find out the connections by connecting a dry battery cell to the wires to identify which wires of speakers sound when battery is connected ,front pair of wires is for front left grey pair is for right front green pair of wires of ur new stereo is for left rear speaker and purple or blue pair is for right rear speaker .these colors are globally known .the wires of speakers must not mixed with each otherblack is for ground negative red is witched power and yellow for permanent power.donot use long screws to fit ur new radio .Best of luck
11/18/2013 8:29:30 PM • JVC KD-S5050 CD... • Answered on Nov 18, 2013
0answers
manual
How do you change the time on a JVC KD-S5050 CD player?
how do i change the time on a jvc kd-6230
2/14/2012 1:59:28 AM • JVC KD-S5050 CD... • Answered on Feb 14, 2012
Cd won't eject. The eject button changes the
Are you sure the face and the body are the same model? It sounds like you don't have the correct face for your deck.
9/26/2011 6:29:54 PM • JVC KD-S5050 CD... • Answered on Sep 26, 2011
0answers
How much was the jvc-kd-s5050 new when they first
The list retail price for this unit originally was $120. However it has been around for a good few years and by 2006 it was retailing for around $75.
Hope it helps. Please leave a vote for the solution. Thanks.
1/26/2011 2:32:15 AM • JVC KD-S5050 CD... • Answered on Jan 26, 2011
I need to know the
the remote wire for your source unit is "BLUE with WHITE" stripe. it can be used for either a power antenna or as a trip wire for an amplifier.
hope this helps and please dont forget to rate.
cheers
1/13/2011 11:30:05 PM • JVC KD-S5050 CD... • Answered on Jan 13, 2011
Don't have manual how do you set clock?
To set the clock on a JVC KD-s5050 cd player, press and hold SEL for more than 2 seconds. Select Clock H. Select the hour
12/7/2010 12:23:46 AM • JVC KD-S5050 CD... • Answered on Dec 07, 2010
Cannot set clock please help
what's the make and model of the unit that you want to set its clock?
Bye now.
11/8/2010 9:04:43 PM • JVC KD-S5050 CD... • Answered on Nov 08, 2010
Spilled soft drink. After clean
did you get all the liquid out from the inside of the deck? there may still be some still between the leads of the output ic. how long was it between the spilling of the pop and the clean-up. if it was a long enough period, the soft drink may have eaten through some of the legs on the output ic.
10/7/2010 5:12:53 PM • JVC KD-S5050 CD... • Answered on Oct 07, 2010
JVC KD-S5050 CD Player Logo
51 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
dont manual set clock
  • Car Audio & Video
