red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
YES IT IS FIX ABLE LOOK FOR A SONY SERVICE CENTER, CHEAPER IN LONG RUN. COUNT THE FLASHES IT SHOULD PAUSE AND BLINK AGAIN FROM LIGHT ON FRONT. DIAGNOSTICS FOR THE TECH.
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Often the number of red flashes symbolize an error message of a specific component. Also try unplugging for an hour or two and try it again to see if problem disappears or changes.
your problem is likely to be in horizontal section of tv.
please take the help of skilled tech.
it is not a major problem but as you know that it is a high voltage device.
