Try relocating the tv. it could be magnetic interference. also make sure that there aren't any speakers too close to the screen (other than the builtin ones of course.)
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Most likely a blown Vertical deflection output IC. In most (but not all) Panasonic, the vertical IC is an AN55XX.
Repairs should be fairly easy with basic knowledge of electronic circuitry and components and a little soldering. I would expect the IC to be readily available at any electronics part store. Should you be uncomfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Your TV has a vertical fault. Based on your description, chances are that it is the vertical IC that went bad. It is relatively a simple repair job and any person with basic familiarity with electronic components and circuitry and soldering would be able to do the job. Should you venture to do a DIY please be reminded of the standard safe practices involve when working inside a TV unit.
