SOURCE: hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
I had this problem. I alternated the hot and cold water valves (changing over the wiring) and then hot tap then dribbled instead of the cold. Replacement part i believe is around $35AU
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
SOURCE: I have a Hoover 750L washing machine and it is not
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
SOURCE: Need wiring schematics for Hoover 750L washing
www.washerhelp.co.uk/diy-repair-help_4.html
www.washerhelp.co.uk/diy-repair-help_3.html
These sites above will help; Yo get a Schematic, you need a service manual, I was unable to find one for your model.
http://appliancejunk.com/forums/index.php?topic=2846.0
This link above, has "Generic" manuals, download one of them, you will find a schematic diagram, of a generic, circuit, they are all pretty much the same, in the add on's to the "Control Board" It will be helpful in tracking any faults, also inside the manual is troubleshooting tips, that apply to ALL, they will help you narrow it down.
Always check, hoses, pump, filters.
might be your drain pipe is too far down the drain tube, take out your pump and clean it.
Check the pump the spade connections , might be a bit loose.
This COULD be a clutch problem. Pads sound like they are gone. If its over 5 years old it will be better to replace. And throw-out bearing in a washer? there is tub and clutch shaft bearings; but it takes quite a bit of experience and tools to change.
good luck and consider shopping around. It is always best to get an Engineer.
Hoover w/m 750 litre model 750LOAUS, catalogue LTL75
