Auto program doesn't find any. Direct input won't work either. The antana works good with other t.v.'s. If I hook up a VCR or converter box on chanel 3 or 4 it won't work, but if it's hooked up with RCA jacks it works fine. I'm thinking it's the tuner on Bord A or the RF antana switch.
SOURCE: picture fuzzy on SONY KP-57WS510
Sounds like bad tuner ( it is soldered in ).
I will research part numbers when i get to work today....T.
SOURCE: lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
SOURCE: chanel button or sony kp-51ws510 51 in rear projection
the circuitry within the TV is where your problem is. thats why your remote wont work it either. Could just be he wire arent pluged in completely or you could have a bad resistor on the control panel PC board. Hope this helps. Let me know if I can assist you any further.
SOURCE: Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
I changed the complete A bord out of a working one with a cracked screen along with the RF along with the RF antenna switch (pictured) and it still won't tune in any channels. Not even if I hook up a VCR on channel 3, nothing. What could be the issue? I have a KDF55WF655, could I change out the whole chassis and put it in the KDF60WF655?
