Also it can be a few other issues:
1: It could be an issue with the lint catcher. Take the lint catcher out, clean off all the see-able lint, then take it to the bathroom and try to run water through it. If the water settles or doesn't run through very well, take an old toothbrush and scrub that clean under water until water passes through easily. This issue caused my dryer to shut off without being dry too
2: Depending on how new your dryer is, it may have a dryness sensor in it. That sensor may not be working well or at all causing the problem as well.
3: Finally your heater could be going out in your dryer and causing it to hot get hot enough in the time you set for the clothes to be dry.
Hope these 3 things help you.
Hello David,
Although you didn't provide any details about your dryer, I have provided a basic tutorial on how a dryer works. Visit this link to view it and order any parts that maybe needed.
Dryer Repair Help
Good Luck!
Rich Lilja
First try cleaning the moisture sensors with rubbing alcohol,
these are two silver colored strips located inside the drier just below the
lint cleanout
