Here's a little video about what happens: https://www.youtube.com/watch?v=318VpMGIQTM&feature=youtu.be I've replaced the t-con panel with a new one. Problem persists.
Tvs have a very complex system inside, when a component goes bad many times they will fire up until they get hot and then quit working, it takes a professional to fix in most cases. you can search you tube for this model and see if anyone has posted a repair for your problem but if you don't know how things come apart or how to solder etc it is best to let a professional repair it or get a newer set
SOURCE: i have a sanyo 42
i got the same problem, just upgrade to hd, call your tv provider, they can help you more, it will probably cost more though
SOURCE: Hello, I'm having an issue with my Sanyo
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
