20 Most Recent
Sanyo DP46848 LCD TV Questions & Answers
I have a SANYO DP46848, after i turn on the TV
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
No picture used to have lines at the top
It could be your current problem, but it is not the problem causing the lines.
You can send the main board to us and we can test it and see how it behaves, possibly fix it, but we likely won't be able to take care of those lines.
Tv flashes on then off
See if you can change the input. and see if it is any better. If not there may be something loose internally. I don't recommend attempting to repair yourself, but having a tech do it can be pricey. Try and leave the TV off for 24 hours and trying again, if it persists you may need to replace the TV. Good luck
